Why not sugar water in tires instead of beet juice?
   / Why not sugar water in tires instead of beet juice? #31
I have seen the ads for beet juice for tires. I have not been able to find pricing. In order to get pricing I must fill out a form with all my info and then I will get a quote. But after speaking to a few folks they spent over 300 bucks per 11.2 x 24 tires. I assume beet juice is used because of all the sugar dissolved into the beet juice. Looking at my Yanmar YM2310 manual it says the tires can be loaded with 235 pounds of a calcium chloride and water solution. Water will dissolve, by weight, pretty much the same amount of sucrose, which is table sugar. Since water weighs about 8 pounds per gallon if I was to make a saturated solution of sugar and water I would need to buy 235 pounds of sugar. Really though, because of the way sugar is packaged in bulk I would need to buy 250 pounds. A quick look online resulted in me finding sugar for 80 cents per pound delivered. So 200 bucks for 250 pounds of sugar. But sugar dissolves 2.4 times, as much, by weight, as calcium chloride into water. So I would need to use more water and less sugar to get to the 235 pound weight shown in the manual. It looks like I can just add sugar water to my innertubes instead of beet juice. Is there a good reason(s) to not use sugar water instead of beet juice? Will it eat up my tubes? I don't get it. Since the sugar water is way less corrosive than calcium chloride I wonder why I have never seen a sugar water solution being mentioned for adding weight. Anybody here have any info on this?
Thanks,
Eric
Last spring I purchased "20 gallons of end of season Walmart windshield washer solution" for $1 per gallon. This is will not freeze down to -15 degrees F.. I also purchased a $10 "valve stem to garden hose connector" from Farm and Fleet. I jacked up each rear tire on my JD2350, removed the valve stem, connected my adapter to the valve stem (top of wheel position) and used a small water feature type low pressure water pump and garden hose to fill each rear tire.
I filled each tire with winter washer fluid only to the top of the rim. Disconnecting the hose, allowed any excess fluid to drain out, then I inserted the tire valve stem, and inflated to the recommended pressure. This gave me 10 gallons of -15 degree anti-freeze solution per tire, or about 80 pounds per tire. The 160 lbs of weight is at or below the top of each rear tire rim. Just where you want it. Simple and inexpensive solution for extra weight down low in your tractor. Dan C.
   / Why not sugar water in tires instead of beet juice? #32
Louisiana.
1 tractor loaded with pure, H2O, tubes.
1 tractor loaded with pure, H20, tubeless.
CT
   / Why not sugar water in tires instead of beet juice? #33
Thanks,
Eric
All ideas are worth considering...I am a beekeeper. To create a 2 sugar 1 water solution one will have to heat the water to melt the sugar. The solution will still form some crystals when it stays cool over time like it does in early spring. These crystals may not be an issue inside a tube.
Before trying on the tires. why not make the solution and put it in the freezer to see how it performs?
Just don't have a pin hole leak and park next to a yellow jacket nest.
   / Why not sugar water in tires instead of beet juice? #34
Possibly, depending on your climate. I don't know if adding sugar to water will lower the freeze point.
Anything dissolved in water will have some impact on freezing point depression. I'm not a chemist but there are ways to calculate the freezing point depression based on the molecular weight of the solute (sucrose), the solvent (water), and percent concentration dissolved. Lots of variables, but there are tables from people who already invented this wheel.
   / Why not sugar water in tires instead of beet juice? #36
I bought an Oliver tractor with 38" tires at an auction years ago. It worked great but had been used for tractor pulls and the rear tires were unknowingly filled with water. When they froze I drove about 100 yards and the tubes got pulverized by the ice frozen solid inside the tires and the tractor returned to the yard with the tires flat on one position only. With every revolution of the tires there was a deep blip when the tractor flopped down like driving over a stump.
Water might be OK for tire ballast in the Caribbean but not
Thanks Garson,
I've been curious about that off and on for years.
   / Why not sugar water in tires instead of beet juice? #37
I’ve used RV antifreeze. Safe for house plumbing, so don’t see any reason it would damage tires and wheels. Works to -20 F. Around $2-$2.50 a gallon
I use the same in the front tires of my Yanmar, to help keep the front planted when I have a heavy load on the rear (no FEL). Also have suitcase weights up front.
I won't need to use a 2 to 1 solution. I might bee able to get by with a 1 to 1 solution. I already have wheel weights mounted that weigh about 70 lbs. each. I looked at a chart and it shows that for the size tires I have each tire filled with 25 gallons will result in an approx. 70% fill. Because of the wheel weights another 200 lbs. of weight need to be added according to the Yanmar manual. At 8 lbs. per gallon it looks like pure water will do. But where I live it does get into the low 20s and rarely into the teens. Not for long, but it does happen. So I am going to find out which will work better for lowering the freezing temperature to 15 degrees F, sugar or the safe anti-freeze. By better I mean weight, cost, and volume wise. This may mean freezing samples myself. With mixed sugar, anti freeze, and water. It could be fun.
Eric
   / Why not sugar water in tires instead of beet juice? #40
Of course that honey will crystalize at around 45 deg.F
2003 International 9200I (A53317)
2003 International...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
2000 Mack CH613 Dump Truck (A59213)
2000 Mack CH613...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
2009 Kubota RTV1140 (A57149)
2009 Kubota...
2015 GENIE GTH-1056 TELESCOPIC FORKLIFT (A59823)
2015 GENIE...
