MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 67,327
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
That's the part that most people don't understand.
I understand that a couple hundred drops of oil is a lot. The oil does not go past the rings. Even if it does, each stroke of combustion burns it off instantly. No worse than "washing" it off with fuel, which I do not think happens in an engine with good rings anyway. As soon as you turn off the key on a car, the spark stops, but the engine keeps spinning for many rotations, which produces suction, which sucks in fuel and air while is spins down. Fuel injected engines probably not so much, but carbureted engines for the last 80 years still sucked fuel and air after the key was turned off. Everything does not stop instantly. There is always going to be fuel and air sucked into a gas engine. I really doubt there is going to be any noticeable wear in an engine if someone gives the throttle a goose before they shut it off. I see no point in doing that, however. Seems strange to rev it up before you shut it down.
