Why idle before shut off?
/ Why idle before shut off? #21
Mine does too and I hate it. It is a John-Deere/Scotts/Home-Depot riding mower with a Kohler engine. I thought something was wrong when I brought it home and shut it off the first time. I looked in the manual and it said to have it at half-throttle (or higher) when you shut it off.
Drives me freakin' nuts. So I basically keep it at full throttle all of the time, running or not.
Everything else I own gets idled down first.
If you have a manual choke, use that to kill the engine.
It won't backfire.
/ Why idle before shut off? #22
It won't backfire.
Then you suck alot more unburned fuel in...not a good thing IMO.
As for the guy starting/stopping at full throttle- probably never change his (warped) mind...just remember to never buy anything used from him:p
My Yamaha Big Bear ATV on shut down makes a nice big thump out the exhaust about 5 seconds later....I've grown a little fond of it:laughing:
/ Why idle before shut off? #23
A lot of mowers and other smaller equipment is that way. And no, if your manual suggests shutting it down like that, then you shouldn't do otherwise and try to kill it with the choke. Shutting the engine down at half-throttle or so won't hurt a thing in situations like this. What you're doing is basically having the throttle plate open wider when you shut the key off. When you shut the key off, it slams the carburetor solenoid closed. Having the throttle plate opened and fuel solenoid closed leans out the mixture enough to prevent the backfiring, because all the backfiring is, is unburnt fuel in the HOT exhaust system lighting off.
If your fuel solenoid is in working order, then the fuel through the main jet gets shut off immediately no matter where the throttle is. That's why they recommend having the throttle open some. The same amount of fuel will still be able to reach the HOT exhaust, but having the throttle plate open a bit introduces enough air into the mix....and the resulting dilution of the air-fuel ratio keeps the backfires from occurring.
/ Why idle before shut off? #24
Thanks for the quick replies. He doesn't just not let it idle , he shuts it off at full throttle, then starts it the same way. Drives me nuts....(easily done).
That is one piece of used equipment I woouldn't want to own, if it ever came up for sale.
/ Why idle before shut off? #25
Turbo charged engines need to run without a load for a few min. after having been run under heavy load to let the turbo cool.
Bill
Bingo! This is the only need for idling an engine before shutdown. Even in the case of a liquid cooled engine that is very hot. Once it is shut down, where will the heat come from?
/ Why idle before shut off? #26
My instructions said to let it low idle for 5 minutes after working before turning off on hot days, so thats what I do. They also say on cold days let it low idle for 5 minutes before starting work, so thats what I do.
/ Why idle before shut off? #27
IMO it doesn't suck in a lot more fuel, because it quits running pretty quickly.
And unlike turning the ignition off, there is spark longer.
There is already a bunch of unburned fuel in there anyway, it's a carburetor.
/ Why idle before shut off? #28
I dont know about you guys, but I dont have anything to work my tractor other than turning the wheels anywhere close to my garage, so it take me 5 minutes or more to get to work. If I am using the bush hog or FEL, I will start the tractor then grease up the joints while the tractor is running as I sometimes need to raise or lower the FEl for the joints to take the grease. This usually takes 5-10 minutes. Even if I do no maintenance, I just idle along at 1200 -1500 RPM for several minutes after start up. On shut down, I do the same if going to the garage, I run slow RPM in a higher gear rather than wide open in low all the way then shut the throttle down and turn off the key. I never shut down immediately from full throttle, but I dont have a problem with really lugging my engine on any of the tractors I have as they have ample power to pull anything I put on them without a strain. I do let them idle down for a minute or so anyway to give the turbo a chance to spin down to minimum RPM. It is going to be hot no matter how long it runs even at an idle so you have diminishing returns. Just look at how long the pilots let the jet turbines cool down after they park-not more than a couple minutes and for sure we dont have any diesel engines running as hot as a jet turbine even the turbo hot side. They may use higher grade oil, but it seems the majority of folks here use synthetic blends so we should be ok on that also. Just a note: Synthetic oil should not be used in any motor during break in period.
/ Why idle before shut off? #29
The heat is already there, from use. But it needs to dissipate...which can be by the coolant flow through the radiator or into the engine block/head. One way or the other, it's going to transfer from the coolant. By idling a few minutes, that gives it time to dissipate through the radiator.
/ Why idle before shut off? #30
To help demonstrate what heat is trapped in the engine, think about this.
When top fuel drag cars finish a run, "smoke" bellows out as they hit the brakes. This "smoke" is NOT the tires.
Many of the top fuel cars have NO radiator. When they reach the end of the run and deploy the brake system, a dump valve opens and dump the water from the engine block into the exhaust system - the "smoke" is actually steam from the hot exhaust vaporising the coolant.
This is done because, if the coolant is not dumped, the residual heat from the engine will overheat the coolant and if the engine stays "closed", it will blow apart.
There may be things they do differently now, I have not kept up with NHRA in recent years. My neighbor is one of the early people of professional drag racing (no, he is not Don Garlits) and he told me the same thing about the coolant and the exhaust as did Kenny Bernstein's team when he was running funny cars.
/ Why idle before shut off? #31
If you are running an engine hard and it is making lots of horsepower, you are burning lots of fuel/unit time. Certain spots in the engine are subjected to much higher heat than a lightly loaded engine, especially the exhaust valves, ports and manifold. If you don't idle for a few minutes to cool these hot spots down after working an engine hard, you do run the risk of warping a head or manifold, especially with the thin wall castings that are so popular wth manufacturers these days.
/ Why idle before shut off? #32
I think by using the choke to kill the engine you would be washing off any oil that would have been left in the cylinder. In other words you would be starting with a dry cylinder next time you fire it up. zman :confused2:
/ Why idle before shut off? #33
I think what youre describing is shutdown at High Idle. While this is full rpm it isnt really full throttle unless the engine is driving a heavy load. ... So altho not the best practice it isnt as bad as it may seem. I really dont like the startup at Hi idle setting tho because that actually is full throttle until the engine reaches the set rpm.
larry
/ Why idle before shut off? #34
I guess the answer is ;
To protect your investment.
E/S
/ Why idle before shut off? #35
if it doesn't have a turbo and the thermostat is working u can shut it down after runnig it 24 hours in 100 degree weather hard and shut it right down because when the thermostat opens it will push the cool water in and the hot water back into the raidator it is not neccasary to let it idle before u shut it down i have ran many tractors and vechicles do u let your car are truck idle for a couple of minutes before u shut it down after u ran it down the highway for two are three hours i bet u dont and dont say there different because a motor is a motor and yes the tractor has just as much air going through the raidator as a car does because most tractor use a pushing fan which push more air than a pulling fan when goin down the road thats why tractors run at lower temps. then cars do
and i doubt anybody on here will set there and let there tractor cool completly down it would take hours because if u think about it diesel fires off of heat and compression not spark so once the motor is hot and the thermostat works it is never going to get hotter than the temp. rating on the thermostat are cooler than the temp. rating thats what it is there for to maintain a constent temp. if i am wrong then what is the thermostat on a tractor for in a car u could say for the heater but no cab no heater
/ Why idle before shut off? #36
Really?
Better tell General Motors to quit shipping brand new cars with synthetic oil in them.
/ Why idle before shut off? #37
What? Where the heck did you get that idea?
/ Why idle before shut off? #38
Interesting thread, if I don't let my sled cool down a minute or 2 after working it hard it backfires and as far as choking off it really helps for restart if your going to leave it overnight and it is really cold. Not sure what that has to do with tractors but I guess it carries over, always let my tractor and duramax for that matter cool down.
Rick
;0Without overly complicating things, I'll stick with my routine of idle down , wait a minute , then shutoff. I'll leave my neighbor alone, let him do his thing and wait and see if anything happens. I'll be first to report if it does. This thread has giving me a lot to digest. So much so, I think I'll hop on the tractor and take a little ride to clear my head. :)
/ Why idle before shut off? #40
if it doesn't have a turbo and the thermostat is working u can shut it down after runnig it 24 hours in 100 degree weather hard and shut it right down because when the thermostat opens it will push the cool water in and the hot water back into the raidator it is not neccasary to let it idle before...
However, the coolant flows stops once the engine is shut down and the thermostat had been open since the engine got to operating temperature.
So, you still have the heat sink situation.
As far as my road vehicle, I don't run the engine hard except when merging on to a highway. Even then, I shift (manual transmission) 1000-2000 RPM below redline. So, it doesn't really get that hot...and ambient (outside) temperature doesn't affect the operating temperature of an engine too much.
At this point, I'd say the guys who shut down immediately will continue to do so..and the guys who idle for a few minutes will also continue to do so. Furthur posts (n this thread) will likely be reiterations of earlier posts.
Not too much use continung...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
2012 INTERNATIONAL 4300 4X2 S/A UTILITY BODY TRUCK (A66091)
2012 INTERNATIONAL...
PALLET OF CUT-OFF VALVES (A68842)
PALLET OF CUT-OFF...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
2018 GENERAC...
2015 KENWORTH T880 (A67714)
2015 KENWORTH T880...
2019 Ford F-550 4x4 Venturo HT40K-X 6,000 lb. Crane Service Truck (A66736)
2019 Ford F-550...
