Why idle before shut off?
/ Why idle before shut off? #101
WHODAT526 wrote: "i just have one more dump question if a farmall cub does not have a water pump, but is water cooled. would that be a exception to the rule or not? because it does have a thermostat does it hurt the motor to just shut it down before idling down."
"i am just curious how that motor cools the water is all i have never worked on one of the motors in a farmall and is curious to know"
The first tractor I was ever on was a Farmall Cub that my Dad had. That was back in the '50's so I don't remember the details on that particular machine. The next tractor was a John Deere B. The old two-cylinder John Deere's did not have a water pump. The water circulated by convection. The hot water rose from the engine to the radiator and cooled water flowed back to the engine through the lower hose or pipe. They had a gradual upward slope from the block to the radiator. The important thing was that they were designed to run without a water pump from the get-go. The pipes did not have dips and curls that would slow down that convection. Modern engines have all kinds of turns and dips in the hoses that make a pump necessary to move the coolant.
/ Why idle before shut off? #102
That is a great question! :anyone:
I would expect that convection circulation is in effect and the running state of the engine would be irrelevant other than to provide an oil bath to certain parts until they cooled sufficiently. I don't know if the engine temperatures get hot enough for this aspect of cooling or metalurgy to be critical though.
Keep talking, I'm learning..........as well as countless others.
/ Why idle before shut off? #103
but would they steadly get hotter and hotter the longer it ran just like when u shut down a engine that has a water pump that is what is am wondering i just cant figure out how they can run so long and not run hot i have ran one for hours at the time it has me puzzled because these tractors seem to contridict what was said in previous post and i dont know how it works but it does just how
/ Why idle before shut off? #104
I personally have never worked on a cub, so I can't answer the question.
But I am looking to possibly buy one...........and after looking over the water circulation process, I'll be sure to post my findings here.
But since you told me about the 'no water pump'........I may have to rethink my ideas.
a farmall cub is a really good little tractor i like the yellow and white version the best u would be surprised at what they can do with only 11 to 13hp
/ Why idle before shut off? #105
The water pump in a modern engine is, in itself, an obstruction to convective flow of coolant. The old non-waterpump engines had no obstructions to hinder the flow of coolant.
/ Why idle before shut off? #106
then what is the use of the water pump other than another part to break and cause major problems
/ Why idle before shut off? #107
I think the answer to that is to further regulate water flow. A too cool engine does not operate well and restricting water flow will speed the warm up cycle for the engine. Once the engine has reached operating temperature, water can be forced in to maintain that temp more effectively with a pump than by relying on convection.
There are trade offs to this process, in both cost and reliability, but it makes operating the machines more convenient.
This lesson was courtesy of my uncle who ran a garage when I was a child, and is only pertinent when the engine is equipped with a thermostat. Convection cooled engines will not have one, but I would expect all modern, pump equipped engines to.
/ Why idle before shut off? #108
The older engines were not as high performance as newer engines. They did not produce as much horsepower per cubic inch of displacement as current engines do. To obtain higher performance, greater efficiency and now, to meet emission standards, an engine has to run at a higher temperature. Natural convection is not sufficient to cool an engine with higher operating temperatures and tighter manufacturing tolerances. More gallons per minute are needed, hence a pump to assist the flow of coolant.
If you look at the oldest stationary, horizontal, single cylinder engines, they did not even have a radiator. They ran so slow and developed so little heat that they were cooled by putting water in a cavity on the top of the engine.
The old John Deeres were slow running too. That's why they had such a large (by today's standards) flywheel. The flywheel kept the engine turning from power stroke to power stroke. That's how they got the name "Poppin' Johnnies". They ran so slow you could hear each cylinder fire individually. They sounded as if they were ready to stall, but the inertia of that large flywheel kept them going.
That's all for tonight, I'm going to bed.
/ Why idle before shut off? #109
i thought the thremostat was for restricting the water flow till it warmed to a certian temp then the thremostat opened until cool water hit it then it closed and the water pump was to pump water not slow it down.
i might have read ur post wrong
/ Why idle before shut off? #110
but a cub dont have a big flywheel and run just as hot as a engine made in the 80s-90s before the major emisions changes i believe
/ Why idle before shut off? #111
When you land an airplane with a carb, it is LEAN because the air is much more dense at ground level than at 5,000 ft.
You should land with full/rich mixture, not lean, because if something wanders into your path you are ready for a go'round. You should lean out at altitude where the air is thin.
/ Why idle before shut off? #112
You read it almost right. I said the pump was to regulate, not restrict. You are correct in that the thermostat restricts; by closing when the water temp is too low. The pump regulates by forcing the flow of water to rapidly cool, and in the case of variable flow pumps, by adjusting the flow rate according to engine speed or electric motor speed regulation.
/ Why idle before shut off? #114
No prob. I am not an engineer or mechanic, so if/when my understanding is erroneous I need you to call me on it so we both know. I will only put out what i think is true and makes sense to me, but we both know in a technical environment one unknown can change an entire philosophy. :thumbsup:
/ Why idle before shut off? #115
Just sitting here looking at the comments. Correct, the add fuel helps cool the engine too. Also enrich the fuel mixture 100 deg under max EGT temp produces Best Power. The extra fuel lowers the combustion temp but increases the mass of the gas in the cylinder hence increasing the Mean Effective Pressure = more hp.
/ Why idle before shut off? #116
if oil is on the cylinder walls above the piston rings u should overhaul that motor oil shouldn't be above the rings that is what the oil ring does clean the cylinder walls free of oil or it will some think of that please and the oil ring is the very bottom ring there will be three rings or more on each piston
and nobody pulls into a parking space and holds the throttle to the floor so u really think when u let of the throttle that cools the motor down right then and there wrong look and the temp gauge it doesn't move
think about what ur saying is u can boil water and then turn off the stove and that water will be cooler if thats the case make a vid of u boiling water and then cut it off and stick ur hand in it and lets see what happens
because this is all the same concept here
There is so much to say here to bring things into perspective. A couple key issues:
-- o - how "free" of oil?
-- o - hot spots
Your mission Zman, should you choose to accept it. ;)
larry
/ Why idle before shut off? #117
-- o - hot spots
larry
this as already been brought into perspective in previous post. i was talking about there was not enough oil in the cylinder walls to drop the oil level in the pan
/ Why idle before shut off? #118
I offered that to someone as an alternative way to kill the motor, when it has a tendency to backfire.
I assume you realize that if you turn the ignition off, there is still fuel going into the engine which is not being ignited, some of which which would be by the way, if your choking it. How do you deal with the damage from that?
Since your acutely aware of engine damage, what about the damage that backfiring can do to an engine?
My 1980's vintage Briggs engine occasionally backfired, even with idle an idle down, which is why I always shut it down with the choke. It seems to run awfully well, even with all the damage it has suffered as a result of this procedure for all these years. :thumbsup:
Yes -- the least of evils. Iv done it myself in those circumstances. There is little damage because the oil is replenished on the 1st stroke. What you dont want in a 4 stroke is real rich long term running.
larry
/ Why idle before shut off? #119
Turbo charged engines need to run without a load for a few min. after having been run under heavy load to let the turbo cool.
Bill
"If" under a heavy load. Most of the time, just shut it down. Regular diesel? I just shut it down. Pretty rare I have a reason to shut of my big truck while doing 65 up a 12% with 80k on. The time it took to get it to wherever it is being shut down allowed plenty of time for the turbo and head to be cooled.
Now, stuck in a hole and boiling over a liquid cooled dirtbike and thinking it is a good idea to shut it down, that's a different story!
/ Why idle before shut off? #120
The oil does not go past the rings. Even if it does, each stroke of combustion burns it off instantly.
Its a matter of degree as to remanent oil film left by rings. And it may be hard to accept, but the combustion does not reach the cyl walls. They are "cold" and the mixture near them is poor due to being stagnant. In a truly cold engine the flamefront stops well short of the walls [a few thousandths "]. At operating temperature it gets closer, but the combustion cycle is so short the flame still cannot breach the proximal growingly stagnant area. The best way I know to see a demo is to wave your propane torch across a piece of hot oiled metal. It wont burn the oil unless you expose it to the torch much longer than a power stroke takes.
larry
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A63569)
2017 TROXELL 150...
2006 Hypac C530AH Pneumatic Wheel Compactor (A66734)
2006 Hypac C530AH...
2015 WINSTON AP22024-DC 24FT EQUIPMENT TRAILER (A66091)
2015 WINSTON...
2012 Chevrolet Impala Sedan. (A66738)
2012 Chevrolet...
1984 Charles Machine Works S4A S/A Tilt Deck Trailer (A61573)
1984 Charles...
Mini Excavator Attachment Set (A64912)
Mini Excavator...
