Why do most tractors with FEL's.........................
   / Why do most tractors with FEL's......................... #11
Read up on calculating hydraulic force which takes into account piston on area. One side of the piston has less area for the oil to push against thus will have less applied from that side.
Think again. The cylinders extend to raise the boom regardless of orientation.
   / Why do most tractors with FEL's......................... #12
The area is the same no matter how the cylinder is pointed.
You CANNOT apply pressure to the rod end and make the cylinder PUSH!
Bruce
   / Why do most tractors with FEL's......................... #13
Extending is typically stronger than retracting, due to the larger area the fluid had to push on... but it doesn't care if the fixed cylinder part is top or bottom.
From a design and manufacturing standpoint, I assume the reasoning for the orientation is shorter hydraulic lines, cheapest.
   / Why do most tractors with FEL's......................... #14
You are right in this application that the push is from the bore side regardless of rotation of the cylinder itself. I was not clear in my initial post on my thought and was thinking a different configuration. But for the cylinder itself I am accurate that more force is applied one way then the other on the rod.
   / Why do most tractors with FEL's......................... #15
I think that's because the rod takes up some space but on the other side there's no rod-just a flat piston head thus giving you an inch or two more area.
   / Why do most tractors with FEL's......................... #16
It's also nice to have the rod seal(s) facing down if stuff spills from the bucket.
I wouldn't want such to accumulate there & score the rod(s).
   / Why do most tractors with FEL's......................... #17
Agreed.
   / Why do most tractors with FEL's......................... #18
True but not germaine to the initial question.
   / Why do most tractors with FEL's......................... #19
I agree on it being for ease of hose placement on quick detach loaders, I was designing a loader a while back and it definitely simplified the plumbing with the base connected to the loaders arm.
If you look at Kubota for axample, the quick detach loaders are oriented this way, the dedicated loaders/ TLB's have the cylinder base mounted to the frame.
   / Why do most tractors with FEL's......................... #20
have the lift cylinders mounted so the rod is fixed to the frame and the cylinder goes up to lift the arm instead of being turned around so the cylinder is fixed to the frame and the rod pushes up the arm?
This means the hoses have to move to follow the cylinder as it moves up and the system requires a little more 'juice' to push the weigh of the cylinders up.
My old Ferguson had the cylinder fixed and the rod went out like I would expect, but newer machines, not so much.
Any ideas?
Example borrowed for clarity:
466465d1461811118-weak-loader-curl-possible-solution-p1030786-jpg
I'm still wondering why there's a cylinder hanging by its hoses out in space in that pic! :)
Husqvarna Riding Mower (A56857)
Husqvarna Riding...
2013 CATERPILLAR D5K2 LGP CRAWLER DOZER (A52709)
2013 CATERPILLAR...
2008 GMC C7500 CREW CAB FLATBED DUMP TRUCK (A57192)
2008 GMC C7500...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
2016 Nissan Frontier Ext. Cab Pick-up (A56858)
2016 Nissan...
2014 Volkswagen Touareg - Turbo Diesel - AWD - 189,609 miles (A55302)
2014 Volkswagen...
