Why do helicopters "chop"?
/ Why do helicopters "chop"? #1
RobertN
Super Member
Shingle Springs California
New Holland TC40D
Why do helicopters \"chop\"?
Why do helicopters make that annoying "chop" sound?
We had one circling nearby this morning. It was rather annoying. I thought maybe it was an air amublance. It got me thinking though... Why do they maker the "chopper" sound? With turbine engines, there is no ignition impulse to affect the rotation of the blades; it should be a steady pressure. It seem they should make a swoosh sound instead.
Why do they make the "chop" sound instead of a swoosh sound? I've been thinking about it, but have not been able to figure it out /forums/images/graemlins/confused.gif
/ Why do helicopters "chop"? #2
Re: Why do helicopters \"chop\"?
Robert, a pilot on Tom Sullivans radio show mentioned the chop. Have you heard the more advanced helicopters. Much less noise. His comment was much shorter blades and better design. Apparently the long blades have tips that approach the speed of sound and in doing so cause so much air turbulence that it results in a lot of noise. I watched a special on copters and was amazed the whole thing holds together. The pitch of the blade is not only adjustable, but in motion actually is changing pitch during the 360 degree rotation, it's what gives the copter its forward speed. They showed it in slow motion with very high speed film. It makes the whole thing look unbelieveably unsafe. I want a ride in one. Rat...
I rode in one on Maui, and years back at the Placer County fair in Roseville. It is fun! Didn't notice the "chop" so much when inside, especially the sight-seer type in Maui...
The shorter blade being quieter make sense. Still though, with the turbine motor is seems the rotation would be smooth. I gotta study this a bit /forums/images/graemlins/smile.gif
/ Why do helicopters "chop"? #4
Helicopter: 10,000 parts flying in lose formation.
Cliff
/ Why do helicopters "chop"? #5
</font><font color="blue" class="small">( Why do they make the "chop" sound instead of a swoosh sound? )</font>
Disclaimer - This is a SWAG from my many years of radar and aircraft experience, but truly just an educated (uneducated?) guess.
I think it's the combination of the low speed blades, turbulent air, and the doppler effect. Since the blade is rotating at constantly changing angles to you, the pressure goes from high to low and the wavefront is perpendicular to your observation point only when the blade is pointing directly at you. At the same time, the doppler effect of the blade is going from positive to negative as the blade passes through that perpendicular point. I believe that is the "chop" sound creator.
Also, many turbo-prop airplanes have a chopping sound, but because their propellers rotate so much faster, the chop becomes a roar and we peceive it differently.
Okay, now someone with real science behind them may correct me, but I don't think I'm too far off. /forums/images/graemlins/blush.gif /forums/images/graemlins/crazy.gif
/ Why do helicopters "chop"? #6
<font color="blue"> I think it's the combination of the low speed blades, turbulent air, and the doppler effect </font>
You nailed it Jim. It's primarily the doppler effect with the blades moving both towards you and away from you. Some of the older military helicopters are very loud and very distinctive because of the size of the rotors.
I've never ridden in a helicopter but it seems like it would be fun /forums/images/graemlins/smile.gif
/ Why do helicopters "chop"? #7
I always thought it was the change in the force of the downward air pressure that reaches the ground as the rotor blades crossed over the tail of the helicopter.
/ Why do helicopters "chop"? #8
Moving away from the physics answer, suffice it to say that the chop sound is a result of the blades annihilating the air that they are flying through. People often take for granted the physical properties of our atmosphere here on earth. Here's a great example: when first learing to fly airplanes, one of the first things you learn is something called a standard rate turn. This maneuver is accomplished by entering into exactly 15 degrees of bank (boy, not sure about the 15 anymore) and holding that angle and exact altitude for exactly 2 minutes. If you can accomplish these few things, you will eventually return (with no wind) to your start completeing a relatively uniform circle. The point is, that I was amazed at when you return to your starting point some 2 minutes later, you run smack dab into the busted up air (prop wash) you made when you started the manuever. A very noticible thump. Way cool.
A lot of existing rotor designs still utilize (for lack of a better word) the concept of a "Jesus" nut.
An old friend of mine flew the Hughies in S.E. Asia. He explained that it got its name because if this nut went, the pilot would utter that same word.
While I've flown a couple of different fixed wing machines, I've only ridden in a heli a couple of times. They are kinda like Corvettes in that it is pure Brute Force technology.
/ Why do helicopters "chop"? #9
</font><font color="blue" class="small">( I've never ridden in a helicopter but it seems like it would be fun )</font>
More fun than a barrel of monkeys. /forums/images/graemlins/wink.gif Especially in the little Bell 47s we had 30 years ago, with the doors off in the summer. I've only been up in a Jet Ranger once for a short ride; all the rest of my helicopter experience was the 47s. I don't know how it is for other folks, but for me, personally, it seemed to take a lot better coordination to fly the helicopter than it did to fly little fixed wing planes.
/ Why do helicopters "chop"? #10
In the early 80's the Detroit Police & Fire Department had an old Vietnam-era Huey that I flew on a couple times carrying patients. That machine had a very loud and distinct "Whomp-Whomp-Whomp" that, to this day, I can tell when the Huey helicoptors are overhead, flying out of Selfridge Air Force Base.
Later we ran an air ambulance service flying a Bell BK117. That coptor had twin turbines, and apparently had a great power-to-weight ratio. I did ~60 patient transfers and scene runs. Every time we took off it was a rush - it was like flooring the pedal for a race car - but straight up!
/ Why do helicopters "chop"? #11
I've been in several..........one overlooking Niagra Falls, what an awesome view. I even got to ride in the original Bat Copter a few years ago.
/ Why do helicopters "chop"? #12
<font color="blue"> Vietnam-era Huey </font>
I can remember standing in my yard as an 7 or 8 year old in the fall of either 1968 or 69. We live in North Central Indiana. We heard this tremendous noise and from the East came several large goups of Hueys. It was normal to see groups of two or three, but these were groups of teens. And it went on all day. That happened several times, as I can recall. Found out later in life that it was probably pilot cross country training on their way to California. Then the helicopters were to be loaded on ships and sent to Vietnam for the war. That noise is something I will never forget. There must have been hundreds of them.
/ Why do helicopters "chop"? #13
<font color="blue"> The point is, that I was amazed at when you return to your starting point some 2 minutes later, you run smack dab into the busted up air (prop wash) you made when you started the manuever. A very noticible thump. Way cool.
</font>
Dap even better than prop wash is the nasty wing tip vortex that is generated by big heavy aircraft. You can't see it but if you are flying slow in preparation to land and you should be unlucky enough to hit it, things can get real exciting very quickly. /forums/images/graemlins/blush.gif
/ Why do helicopters "chop"? #14
Yup. Was trying to keep this a 'family rated' post though. Been there, done that, but had to throw the T-shirt out for obvious reasons. /forums/images/graemlins/grin.gif
FAA enforces 5 mile separation for the liners. Unfortunately, a small plane can still get shook up pretty good. That 5 mile separation is really a measurement in time not so much distance. They figure enough vortex disipation will occur for one liner flying into the vortex of another. Go head, fly directly 5m behind a 737 in a Warrior II. Only thing missin is a guy to collect your ticket, strap you in and set the lap bar!
/ Why do helicopters "chop"? #15
</font><font color="blue" class="small">( It's primarily the doppler effect with the blades moving both towards you and away from you. )</font>
In radar terms in the late 70s, we call that "zero beat" because on a doppler radar it looked like you had an equal number of targets both inbound and outbound on each side of zero. Normally you had circuitry that would cancel out equal signals like that because they were caused by big slow-moving (relative to jets) helos. /forums/images/graemlins/cool.gif
/ Why do helicopters "chop"? #17
I'm trying to work off memory, but, we know how that is.. THe swashplate at idle, a crew chief can almost run his hand in and out of the turn mass near the Jesus nut.. However, the end tip of the advancing blade almsot nears the speed of sound. The retreating is slower, entering a faster air mass. The blade chord and angle of attack has a lot to do with it also. I did a little over 1200 hours in a Huey, but that was over thirty years ago.. I still takes rides several times a year in Cessna 152/172. If I had the chance, I'd drop everything just to go flying.
/ Why do helicopters "chop"? #18
Here Doc, take a ride on a Huey CLICK HERE then push the click here to enjoy a Huey ride button below the picture.
/ Why do helicopters "chop"? #19
gator..........that was great....... /forums/images/graemlins/laugh.gif
2018 Club Car Carryall 1700 4x4 Diesel Utility Cart (A61572)
2018 Club Car...
2021 HYUNDAI HX220L EXCAVATOR (A60429)
2021 HYUNDAI...
UNVERFERTH 12R30" RIP STRIPPER (A63291)
UNVERFERTH 12R30"...
2007 John Deere 1790 Planter (A63111)
2007 John Deere...
HARDEE 92" X18' BOGGIE AXLE METAL TRAILER (A63291)
HARDEE 92" X18'...
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
