Why can't I delete a post????
/ Why can't I delete a post???? #1
JDgreen227
Super Member
Central Michigan
4210 MFWD Ehydro--'89 JD 318
Have a duplicate post in "Rural Living" that I want to delete but when I click on "Edit/Delete" it WILL NOT give me the option to delete the post. Why not? All I have the option of doing is "Save" or "Go advanced" ???
/ Why can't I delete a post???? #2
k0ua said:
edit post.. go advanced. the delete box is up at the top.
James K0UA
There's already a thread answering this in the "News/Feedback" section.
Thanks, I read that but it does not address my issue. I composed a new thread in "Rural Living" about a sprayer fix, and tried to post it, and my browser hung up for 3-4 minutes and would not let me do anything, I had to go to Task manager and shut down my computer and restart it, and then I went to TBN/Rural Living again and my thread had not shown up so I redid it and posted it and then BOTH THREADS showed up. Apparently there is no means for someone to delete a THREAD, just a post. I can understand that, but in the situation I was in, as OP having having a near-dupicate thread with only one view on each and no replies there should have a way I could delete one of the threads.
/ Why can't I delete a post???? #4
JD, one of your threads has 3 replies. The other had none, so I deleted the one with no replies. As mentioned above by others, you can delete your own posts, within a certain length of time, but I didn't know you couldn't delete a thread, if in fact, that's the case. But you can always click on the little triangle in the lower left corner of a post and ask the moderators to remove it for you.
Thanks Bird....I felt rather foolish that I started two near-identical threads because my ISP was so slow and was hoping there was a way to delete one of them. Appears not, and thanks for the information about how to inform a moderator that I want a thread removed, and for removing the one with no replies.
/ Why can't I delete a post???? #6
No need to feel foolish. It's happened to others, too.
/ Why can't I delete a post???? #7
You should be able to edit/delete within 12 hours.
/ Why can't I delete a post???? #8
There does seem to be a problem with double posts. My browser, Apple, has also hung up and done that. I see more doubles recently so I am sure others have had the problem.
MarkV
/ Why can't I delete a post???? #9
For some reason since the update I have had multiple double posts, but the delete function has allowed me to delete the doubles.
I wonder if anyone is looking to fix the problem with what is causing the double posts
I should make another clarification of this thread....I originally stated I could not delete a POST, but the issue was I could not delete an unwanted and redundant THREAD....it appears there is no way for a member to delete a thread once it has shown up in the forums. Thank you, Muhammad....and also to Bird for taking the time to clarify the issue.
/ Why can't I delete a post???? #11
Similar problem - I put a typo in the title, I blame it on the small font. After noticing it, and knowing I could not change the title, I went back to delete the post. Couldn't do it. Of course that might have deleted the thread.
2014 Crane Carrier Co. Low Entry T/A Rear Loader Garbage Truck (A66736)
2014 Crane Carrier...
2014 FREIGHTLINER M2 4X2 S/A CNG FLATBED WITH CRANE TRUCK (A66091)
2014 FREIGHTLINER...
2014 KENWORTH T370 ROAD TRACTOR (A64280)
2014 KENWORTH T370...
PVC PIPE FITTINGS (A64276)
PVC PIPE FITTINGS...
2025 Rake Mini Excavator Attachment (A66734)
2025 Rake Mini...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
