Who Uses CB Radios?
   / Who Uses CB Radios? #11
I always have a CB in my RV's for any traffic info on the road.
My dad got his CB licence in the late 50's, had call sign 19W----.
He built his own transmitters and receivers from military surplus, also for friends.
He even made his own crystals from old military surplus!
He could buy 10 for a dollar, take out the crystal and grind it on a piece of glass with cleanser to the right frequency. If he missed it cost a dime. Store bought crystals were about $5. and you needed 2, broadcast and receive.
I know, they were the bain of my existence in the CB era. I never owned a 23 channel rig because I had no money and farted around with a few channels on X-Tals! That was a lot of money back then. Five dollars could probably feed a family of ten (no doubt driving a Vista Cruiser) at McDonalds and get change back!
   / Who Uses CB Radios? #13
Just my guess about Marine UHF or lack thereof. I would say, you get more range over water with VHF.
Yes but UHF would be useful in some popular spots where the body of water is only about 3 miles across, we are also required to carry HF for serious offshore cruising.
VHF is also more expensive than UHF but if you can afford a vessel you should be able to afford a radio.
If you get caught without one the fine is more than a radio.
I ran a UHF repeater VE3MPR for many years and had Frequency Agile Cross band to VHF, so I am not unfamiliar with the coverage of both, but don't understand your thinking. Are you talking lack of band space for a lot of traffic?
   / Who Uses CB Radios? #15
VHF is line of sight for the antenna, CG, Marine Patrol have very high antennas and boats need antenna mounted as high as possible.
Civilians are limited to 25 watt but the Pros can crank up their wattage for emergencies.
Have heard CG Tampa when offshore Jacksonville like they were parked next to me!
Some think their VHF is a CB.
Some think any two way radio is a CB! Many movies certainly promoted that notion.
   / Who Uses CB Radios? #17
When I was working (retired now) I had a CB installed in my commuter vehicle. I live about 12 miles from I-80; when I pulled out of the garage on a winter morning I would turn on the CB and within 5 minutes would have a complete idea of what the road conditions were and any trouble spots, just from the truckers talking to each other. Very handy, and some mornings that information would determine the route I would take to work. And in the afternoon, I would listen to some entertaining conversations between the truckers and the ladies at the local cat houses!
Information for newbies to the CB world - the quality of the antenna is more important than the radio. And that antenna must be "matched" to the radio. That makes the most difference in how much range your radio will have!
I have a Bird Wattmeter with only a 100 Watt Element in that band. Now I'm thinking of spending eighty bucks for a lower wattage element (slug) for my new four dollar radio. The 100 watt set up tells me that my Larson NMO-27 is well matched, but a lesser wattage slug would give me better resolution especially for reflected power.
I remember as a kid, once trying underground shielded telephone cable as coax and a chromed ski pole for an antenna! There was no Internet to find stuff out.
   / Who Uses CB Radios? #19
I use to have a 23 channel. Might still be out in my shed but pretty sure the antenna is long gone. We used them mostly when hunting with dogs. Haven't hunted in 30 years though.
   / Who Uses CB Radios? #20
I still have a 18 ch 27mhz base station in pristine order. It would suit a collector sometime. I also have 3 Icom Uhfs and some Taits and Phillips Uhfs. I can program them to whatever frequency I need. I still use one in my car for road reports to find out where the cameras are, but the others are unused now. One day I may get an offer for them but I will always keep a couple. I threw some Icom handhelds in the bin recently as they were just gathering dust.
SEET BOX W/ CABLE SLINGS (A54756)
SEET BOX W/ CABLE...
2017 Nissan NV200 Cargo Van (A53422)
2017 Nissan NV200...
BUNDLE OF 25" - 49", 2" X 2" TUBING (A54756)
BUNDLE OF 25" -...
2016 FREIGHTLINER CASCADIA (A53843)
2016 FREIGHTLINER...
1994 INGERSOLL RAND SD100D PADFOOT ROLLER (A52706)
1994 INGERSOLL...
BUNDLE OF 6" X 12" BUILDING PURLIN (A54756)
BUNDLE OF 6" X 12"...
