Who runs a CV joint on their PTO shaft
   / Who runs a CV joint on their PTO shaft #1
sea2summit
Super Member
Left coast of, GA
Kubota 1860->25D, MX5800, M4D
I've got a 9' disc mower for hay I put on a caddy, it has a Walterscheid overdrive shaft from the caddy to the mower but I'm getting some vibration on turns and I'd rather not blow a $2k gearbox if I can avoid it. I think I need to upgrade the PTO shaft form the tractor to the Caddy with a CV joint. Anyone have a preferred one? I'd rather upgrade the shaft just add one on...I think that will be cheaper anyway.
Next question, do I need one on both ends of that shaft? Seems like a lot of the prebuilt shafts have an 80 degree joint on one end and 50 degree on the other.
   / Who runs a CV joint on their PTO shaft #2
CV joints are expensive too. Maybe watch turning so short. I cut the long straight runs. Cut both ends of a field first. Unless it is exactly square, it's gonna have a long side and short side. Real CV joints are a pain to re do. You'll wish you had five hands.
   / Who runs a CV joint on their PTO shaft #3
These people have a good selection of PTO shafts, with one or both ends and sorted by horsepower;
Bare Co USA - Wide Angle CV Shafts
Quite often just the tractor end will have the CV as it is usually the end that gets the most articulation.
   / Who runs a CV joint on their PTO shaft #4
I have a 10' Kodiak pull behind mower and make frequent sharp turns with no issues with the CV pto that came with it.
Idaho2
   / Who runs a CV joint on their PTO shaft #5
So does Agri Supply. I have a double Cardan on my disc bine. So long as you keep it lubricated, it's no issue.
Came close to grabbing one there last weekend but it seems really long requiring a shaft trim so I figured I should research some first.
   / Who runs a CV joint on their PTO shaft #7
My Frontier FM has one and I'm going to put oine on my Maschio flail since that one works so well.
   / Who runs a CV joint on their PTO shaft #8
Cardan is what came with my 10' Kodiak/Mahindra mower.
   / Who runs a CV joint on their PTO shaft #10
I lost a CV joint a while back on a baler, I ran a single joint for years, but severely limited turning radius. I could not rebuilt the original Weasler CV, was completely shot. I also could not easily find the CV end to fit my implement end.
Ended up buying a complete replacement assembly made by B&P(Italy). Spending 4 figures on a driveshaft wasn't fun, but being able turn and not risk vibration was well worth it.
LOT: Fill-Rite Pump, Fuel Transfer Tank, Tool Box (A59076)
LOT: Fill-Rite...
2012 PETERBILT 337 (A58214)
2012 PETERBILT 337...
12ft x 20ft Steel Carport (New/Unused) (A59225)
12ft x 20ft Steel...
1991 John Deere 4755 Tractor (A59814)
1991 John Deere...
2017 RAM 2500 (A58214)
2018 Ford F-150 4x4 Pickup Truck (A56858)
2018 Ford F-150...
