sea2summit
Elite Member
I've got a 9' disc mower for hay I put on a caddy, it has a Walterscheid overdrive shaft from the caddy to the mower but I'm getting some vibration on turns and I'd rather not blow a $2k gearbox if I can avoid it. I think I need to upgrade the PTO shaft form the tractor to the Caddy with a CV joint. Anyone have a preferred one? I'd rather upgrade the shaft just add one on...I think that will be cheaper anyway.
Next question, do I need one on both ends of that shaft? Seems like a lot of the prebuilt shafts have an 80 degree joint on one end and 50 degree on the other.
