Who runs a CV joint on their PTO shaft
   / Who runs a CV joint on their PTO shaft #1
sea2summit
Super Member
Left coast of, GA
Kubota 1860->25D, MX5800, M4D
I've got a 9' disc mower for hay I put on a caddy, it has a Walterscheid overdrive shaft from the caddy to the mower but I'm getting some vibration on turns and I'd rather not blow a $2k gearbox if I can avoid it. I think I need to upgrade the PTO shaft form the tractor to the Caddy with a CV joint. Anyone have a preferred one? I'd rather upgrade the shaft just add one on...I think that will be cheaper anyway.
Next question, do I need one on both ends of that shaft? Seems like a lot of the prebuilt shafts have an 80 degree joint on one end and 50 degree on the other.
   / Who runs a CV joint on their PTO shaft #2
CV joints are expensive too. Maybe watch turning so short. I cut the long straight runs. Cut both ends of a field first. Unless it is exactly square, it's gonna have a long side and short side. Real CV joints are a pain to re do. You'll wish you had five hands.
   / Who runs a CV joint on their PTO shaft #3
These people have a good selection of PTO shafts, with one or both ends and sorted by horsepower;
Bare Co USA - Wide Angle CV Shafts
Quite often just the tractor end will have the CV as it is usually the end that gets the most articulation.
   / Who runs a CV joint on their PTO shaft #4
I have a 10' Kodiak pull behind mower and make frequent sharp turns with no issues with the CV pto that came with it.
Idaho2
   / Who runs a CV joint on their PTO shaft #5
So does Agri Supply. I have a double Cardan on my disc bine. So long as you keep it lubricated, it's no issue.
Came close to grabbing one there last weekend but it seems really long requiring a shaft trim so I figured I should research some first.
   / Who runs a CV joint on their PTO shaft #7
My Frontier FM has one and I'm going to put oine on my Maschio flail since that one works so well.
   / Who runs a CV joint on their PTO shaft #8
Cardan is what came with my 10' Kodiak/Mahindra mower.
   / Who runs a CV joint on their PTO shaft #10
I lost a CV joint a while back on a baler, I ran a single joint for years, but severely limited turning radius. I could not rebuilt the original Weasler CV, was completely shot. I also could not easily find the CV end to fit my implement end.
Ended up buying a complete replacement assembly made by B&P(Italy). Spending 4 figures on a driveshaft wasn't fun, but being able turn and not risk vibration was well worth it.
1986 Betenbender 175 Ton 10 Ft Press Brake (A59213)
1986 Betenbender...
(APPROX. 20) 4' X...
Toyota 7FDKU40 7,350lb Forklift (A55973)
Toyota 7FDKU40...
2007 JLG 660SJ TELESCOPIC BOOM LIFT (A52709)
2007 JLG 660SJ...
2018 Deere 323E (A53317)
2018 Deere 323E...
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
