Who plugs tires?
   / Who plugs tires? #71
Exactly, same reason you can't get them to install a tube anymore.
I had always thought that tubes inside tubeless tires at road speeds were legitimately dangerous, due to friction and heating at high speed. Not true?
I use them in tractor and mower tires, when all options to remain tubeless have been exhausted, but never even considered a tube in an on-road vehicle.
   / Who plugs tires? #72
Don't know about cars/trucks, I've only used them on old, rusty trailer wheels (which they still wouldn't put tubes in), and have never had a problem.
   / Who plugs tires? #73
Legal repair? Is there a state board of legal tire repair methods?
Not sure what entity decides these things, but for a tire to be repaired it has to be dismounted and the liner sealed from the inside. A plug is not a legal repair.
I've been happy with tirerack.com
They will mount and balance on your new wheels or deliver to your tire shop
If buying tires and wheels, which I sometimes do, be aware that while Tire Rack uses good Hunter balancers, they run them with the Smart Weight function on.
That results in a less than perfect balance, so the first thing I do is balance them correctly, then put them on the vehicle. There's often quite a difference between where and how much weight is needed to achieve perfection vs. as delivered.
   / Who plugs tires?
I did get 1 out 8 that needed a balance correction
   / Who plugs tires? #75
That's partially why the inside of the tire should have talcum powder or something similar applied, to lessen the friction.
And most wire wheeled cars run tubeless tires with tubes in them.
   / Who plugs tires?
And how did you tell?
By it being bad enough that you felt the vibration, or by running the tire and wheel on a road force balancer?
Yes bad enough I could feel a vibration at a certain speed. I moved it around until I determined which one it was. Had it rebalanced, problem solved.
   / Who plugs tires? #78
BTW, Revels Fast Lube, Starke, FLa. They arent "fast" or "cheap" but they are good, and not that much more than a 5 minute oil changes place...
Thanks! But quite a cruise for me, . . . . .
It's sure nice having a local that you can drop off tires with just a phone # when closed.
I've had a LOT of tubes in tires that don't get moved often and I prefer them for that waaay over tubeless. Stay full for years.
   / Who plugs tires? #79
Say what..a legal repair? What’s a “legal repair” mean exactly? Tire companies say don’t fix their tires? That’s not a law. Again, Says who? Where?
NH has always had strict vehicle inspections, and a tire with a functioning gummy worm repair is completely legal.
You speak like you’re insinuating the entire country… I’m genuinely curious where you’re getting this apparently federal law from, that Ive never heard of.
Sorry gotta call bs
   / Who plugs tires? #80
And here I thought it was common knowledge. Guess it's not.
Anyway, tire manufacturers, the DOT, the Tire Industry Association, USTMA, and others have pretty much all agreed on what constitutes a legal repair.
There must be lots of easily obtained information on the subject, but I'm not into spoon feeding so you're on your own for the specifics.
2007 Bomag BW120AD-4 Tandem Vibratory Smooth Drum Roller (A52377)
2007 Bomag...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2015 Peterbilt 320...
FRONTIER MG20F LOT NUMBER 80 (A53084)
FRONTIER MG20F LOT...
2017 Makita HM1307CB 35lb Demolition Hammer (A52377)
2017 Makita...
Adams 5 ton Fertilizer Buggy / Wagon (A53473)
Adams 5 ton...
Ford F450 Bucket Truck with Altec AT200A Boom (A55218)
Ford F450 Bucket...
