Who needs a thumb?!
/ Who needs a thumb?! #21
A thumb on a backhoe is as useful as a human thumb. Just think how handicapped one would be without his thumb. Well the backhoe is just as handicapped without a thumb and a hydraulically adjustable thumb is really the only way to go with one.
/ Who needs a thumb?! #22
I have a manual one on my BH77 ( L3700 SU ) it's ok ..but the limited length of the hoe and relatively small radius of it..really limits its usefulness. I also have a KX121 with a hydraulic thumb.... its night and day more useful and about 300x faster and probably 6x stronger. At this point the hoe on the back of the tractor..is basically ballast for the grapple.
/ Who needs a thumb?! #23
I am always trying to get a bit more functionality out of the B21. Rather than get another machine. That is why I made the hyd thumb with progressive linkage. The hyd actuation is very important as Gary said. With the progressive linkage the thumb gets 180 degrees range of motion and a lot more reach than any mechanical thumb. Direct link hyd thumbs get 90-110 degrees range of motion. It makes a difference. When I was mocking it up I got 210 degrees of motion but dialed that back to avoid excess force on the components. Also with progressive linkage the cyl stays close to the stick, compared to direct linkage, and out of harm's way for instance when dumping into a trailer.
/ Who needs a thumb?! #24
I was just thinking. I don't think I have EVER seen a commercial TLB with a thumb.
/ Who needs a thumb?! #25
/ Who needs a thumb?! #26
Note to self. . . . One.
Betcha he didn't get far with that wide load. Seems to me, a logging style grapple would be infinitely more useful. I know it would be for me.
/ Who needs a thumb?! #27
A full size TLB without a thumb is really missing out. Now imagine if it was hydraulic and had a quick attach bucket with 3rd function hydraulics.
/ Who needs a thumb?! #28
Many guys that have a full size TLB also have an excavator. Then, a thumb really comes into it's own. With reach, height and 360 degree operation.
/ Who needs a thumb?! #29
I’d like to have a midi excavator in the 10 ton range but a thumb was cheaper than another machine.
/ Who needs a thumb?! #30
I'd like to see an **affordable** attachment that replaces a small BH bucket; claw like with full rotation.
/ Who needs a thumb?! #31
I would like that on the front SS attach. It's a compromise, since you have to drive backwards. But hey, your neck does need excercise. Also, you don't have to turn around and deploy the backhoe.
/ Who needs a thumb?! #32
Good luck on that. I’ve never seen a small one. Most of those are on bigger log loaders and are a complicated attachment that aren’t cheap.
/ Who needs a thumb?! #33
Don't many of the smaller (non commercial) forwarders use them?
By the time I get one built or found, my piles of pine slash will be decomposed anyway.
/ Who needs a thumb?! #34
Yes .... I understand. But then again, they used to say that about backhoes, grapples, graders (box blades) and a number of other things.
I mean, ya' know, they put them in vending machines to pick up toys, so ....
/ Who needs a thumb?! #35
What would you use the rotary claw for? They’re a necessity for loading logs but I don’t see much advantages and in many cases inferior to a hydraulic thumb.
/ Who needs a thumb?! #36
A vending machine that dispenses mostly frustration.
Log grapples are so cool because you can pick up several large logs or just one toothpick (held firmly) with the same claw.
/ Who needs a thumb?! #37
That may not be what's going on there. Looking back on the picture on message #25, I often do the same - I use the thumb to pick up a downed tree to about that height to make it easier to limb and then chainsaw into sections.
BTW, around here most TLBs have thumbs now, but thumbs were rare 20 years ago. I wouldn't buy one today without a thumb.
rScotty
/ Who needs a thumb?! #38
Post 25 was posted by me and there is a thumb on it. IMG_2064.JPGIMG_2054.JPGIMG_1990.JPG
New/Unused Quick Attach Skid Steer Brush Cutter (A61166)
New/Unused Quick...
8064 (A61166)
8064 (A61166)
2015 Jeep Wrangler Rubicon Vehicle (MPV), VIN # 1C4BJWFG8FL728783 (A61165)
2015 Jeep Wrangler...
(2) UNUSED KUBOTA 6 LUG WHEEL/CENTERS (A62130)
(2) UNUSED KUBOTA...
Polaris Ranger 400 H.O. (A61166)
Polaris Ranger 400...
John Deere 568 Mega Wide Plus (A60462)
John Deere 568...
