Buying Advice who makes the biggest EFI small engine?
   / who makes the biggest EFI small engine? #1
kdlklm
Saskatchewan, Canada
Kubota BX1830
I have been looking at a Kohler 40 hp engine for a machine that I'm building. But I really like the electronic fuel injection engines. I would like to get as close as I can to a 40 hp horizontal shaft engine. Who makes the biggest one that you know of in the EFI.
   / who makes the biggest EFI small engine? #2
You should list more parameters for specs. Gas or diesel, air or water cooled, weight restrictions and any thing else that is pertinent.
Over the last 10 or 15 years I have watched the air cooled horizontal shaft motors rise in hp, 40 hp is higher than I have seen. If this is a DIY project then consider a used aircooled VW motor too, if more power is needed.
   / who makes the biggest EFI small engine? #3
I haven't looked at the specs but could you make and ATV engine work? I don't know if it would fit what you need but you can get them with EFI and over 40hp.
Ed
I am looking for an air or liquid cooled engine, gas and there are no really other specs that I need to worry about. Kohler makes a 29 hp engine, But I was hoping to get a little larger than that. And I also want to stay under the $4000 range
   / who makes the biggest EFI small engine? #5
I looked aroud somemore and here are a few near 40hp with EFI.
Cam-Am 500, 40.4hp
Type 499.6 cc, V-twin, liquid-cooled, SOHC, 8-valve (4-valve/cyl)
Bore & Stroke 82 x 47 mm
Arctic Cat 700, 41.4hp
Displacement 695 cc
Engine Type SOHC, liquid cooled, 4-stroke, 4-valve w/EFI
Bore & Stroke 102 x 85 mm
Yamaha 700, 45.6hp
Type 686cc, 4-stroke, liquid-cooled single; SOHC, 4 valves
Bore x Stroke 102.0mm x 84.0mm
Compression Ratio 9.2:1
I would think you could just walk into an ATV dealership and order an engine as if you were replacing one in an atv but I don't know if they will work size wise.
   / who makes the biggest EFI small engine? #6
Kawasaki sells engines and their stuff has always been top notch in my various ATV's, UTV's, lawnmowers, dirtbikes, etc...
It looks the largest horizontal shaft engine they sell is a 31 hp / 55 lb.ft. V-twin OHV Fuel Injected 825cc liquid cooled engine and weighs 127 lbs.
Kawasaki Engines and Power Products - Engines - FD851D-DFI
yes I have seen that engine, and they do make a 37 hp vertical shaft engine, but I don't know if I want to make a compromise to go with a vertical shaft. Because it is going to have a triple hydraulic pump attached to it.
I made a few phone calls and ATV engines are not that easy to get. Plus it would be a lot of retrofitting.
   / who makes the biggest EFI small engine? #8
Can you list the pump and its requirements?
   / who makes the biggest EFI small engine? #9
Check out the surplus supply store that advertises on this site... they have a Kubota diesel around 47 hp, for less than $4000.00.
I don't have the specs on the pump handy right now, but a smaller engine will run the pumps, but I want to be able to add other stuff later like a PTO.
2007 Caterpillar D5G LGP (A53317)
2007 Caterpillar...
UNUSED FUTURE FT13CJ EXCAVATOR (A57192)
UNUSED FUTURE...
2019 Ford F550 Chassis (A55973)
2019 Ford F550...
2012 MACK GU713 (A58214)
2012 MACK GU713...
2010 International 4300 2,000 Gallon Water Truck (A55973)
2010 International...
2014 Ram 1500 4x4 Crew Cab Pickup Truck (A56858)
2014 Ram 1500 4x4...
