Buying Advice who makes the biggest EFI small engine?
/ who makes the biggest EFI small engine? #1
kdlklm
Saskatchewan, Canada
Kubota BX1830
I have been looking at a Kohler 40 hp engine for a machine that I'm building. But I really like the electronic fuel injection engines. I would like to get as close as I can to a 40 hp horizontal shaft engine. Who makes the biggest one that you know of in the EFI.
/ who makes the biggest EFI small engine? #2
You should list more parameters for specs. Gas or diesel, air or water cooled, weight restrictions and any thing else that is pertinent.
Over the last 10 or 15 years I have watched the air cooled horizontal shaft motors rise in hp, 40 hp is higher than I have seen. If this is a DIY project then consider a used aircooled VW motor too, if more power is needed.
/ who makes the biggest EFI small engine? #3
I haven't looked at the specs but could you make and ATV engine work? I don't know if it would fit what you need but you can get them with EFI and over 40hp.
Ed
I am looking for an air or liquid cooled engine, gas and there are no really other specs that I need to worry about. Kohler makes a 29 hp engine, But I was hoping to get a little larger than that. And I also want to stay under the $4000 range
/ who makes the biggest EFI small engine? #5
I looked aroud somemore and here are a few near 40hp with EFI.
Cam-Am 500, 40.4hp
Type 499.6 cc, V-twin, liquid-cooled, SOHC, 8-valve (4-valve/cyl)
Bore & Stroke 82 x 47 mm
Arctic Cat 700, 41.4hp
Displacement 695 cc
Engine Type SOHC, liquid cooled, 4-stroke, 4-valve w/EFI
Bore & Stroke 102 x 85 mm
Yamaha 700, 45.6hp
Type 686cc, 4-stroke, liquid-cooled single; SOHC, 4 valves
Bore x Stroke 102.0mm x 84.0mm
Compression Ratio 9.2:1
I would think you could just walk into an ATV dealership and order an engine as if you were replacing one in an atv but I don't know if they will work size wise.
/ who makes the biggest EFI small engine? #6
Kawasaki sells engines and their stuff has always been top notch in my various ATV's, UTV's, lawnmowers, dirtbikes, etc...
It looks the largest horizontal shaft engine they sell is a 31 hp / 55 lb.ft. V-twin OHV Fuel Injected 825cc liquid cooled engine and weighs 127 lbs.
Kawasaki Engines and Power Products - Engines - FD851D-DFI
yes I have seen that engine, and they do make a 37 hp vertical shaft engine, but I don't know if I want to make a compromise to go with a vertical shaft. Because it is going to have a triple hydraulic pump attached to it.
I made a few phone calls and ATV engines are not that easy to get. Plus it would be a lot of retrofitting.
/ who makes the biggest EFI small engine? #8
Can you list the pump and its requirements?
/ who makes the biggest EFI small engine? #9
Check out the surplus supply store that advertises on this site... they have a Kubota diesel around 47 hp, for less than $4000.00.
I don't have the specs on the pump handy right now, but a smaller engine will run the pumps, but I want to be able to add other stuff later like a PTO.
that would be sweet, but it's a little big to fit in what I need. Plus almost nothing comes with it, and after everything was purchased, it would be well over my budget. But that's a very impressive price.
/ who makes the biggest EFI small engine? #12
Just go snatch the motor out of a Mini Cooper. Check out the motorcycle salvage yards. Some of those Crotch rocket bikes that outlived the driver might be cheap sources.
BOWMAN WEED WICK & MOUNT (A63291)
BOWMAN WEED WICK &...
24220 (A56859)
24220 (A56859)
2010 Ford F750 Single Axle Dump (A62613)
2010 Ford F750...
2007 JLG E400AJP TELESCOPIC/SCISSORING MANLIFT (A52709)
2007 JLG E400AJP...
2003 McCormick XTX 185 XtraSpeed Tractor (A63688)
2003 McCormick XTX...
Mini Skid Steer (A60352)
Mini Skid Steer...
