Buying Advice who makes the biggest EFI small engine?
/ who makes the biggest EFI small engine? #1
kdlklm
Saskatchewan, Canada
Kubota BX1830
I have been looking at a Kohler 40 hp engine for a machine that I'm building. But I really like the electronic fuel injection engines. I would like to get as close as I can to a 40 hp horizontal shaft engine. Who makes the biggest one that you know of in the EFI.
/ who makes the biggest EFI small engine? #2
You should list more parameters for specs. Gas or diesel, air or water cooled, weight restrictions and any thing else that is pertinent.
Over the last 10 or 15 years I have watched the air cooled horizontal shaft motors rise in hp, 40 hp is higher than I have seen. If this is a DIY project then consider a used aircooled VW motor too, if more power is needed.
/ who makes the biggest EFI small engine? #3
I haven't looked at the specs but could you make and ATV engine work? I don't know if it would fit what you need but you can get them with EFI and over 40hp.
Ed
I am looking for an air or liquid cooled engine, gas and there are no really other specs that I need to worry about. Kohler makes a 29 hp engine, But I was hoping to get a little larger than that. And I also want to stay under the $4000 range
/ who makes the biggest EFI small engine? #5
I looked aroud somemore and here are a few near 40hp with EFI.
Cam-Am 500, 40.4hp
Type 499.6 cc, V-twin, liquid-cooled, SOHC, 8-valve (4-valve/cyl)
Bore & Stroke 82 x 47 mm
Arctic Cat 700, 41.4hp
Displacement 695 cc
Engine Type SOHC, liquid cooled, 4-stroke, 4-valve w/EFI
Bore & Stroke 102 x 85 mm
Yamaha 700, 45.6hp
Type 686cc, 4-stroke, liquid-cooled single; SOHC, 4 valves
Bore x Stroke 102.0mm x 84.0mm
Compression Ratio 9.2:1
I would think you could just walk into an ATV dealership and order an engine as if you were replacing one in an atv but I don't know if they will work size wise.
/ who makes the biggest EFI small engine? #6
Kawasaki sells engines and their stuff has always been top notch in my various ATV's, UTV's, lawnmowers, dirtbikes, etc...
It looks the largest horizontal shaft engine they sell is a 31 hp / 55 lb.ft. V-twin OHV Fuel Injected 825cc liquid cooled engine and weighs 127 lbs.
Kawasaki Engines and Power Products - Engines - FD851D-DFI
yes I have seen that engine, and they do make a 37 hp vertical shaft engine, but I don't know if I want to make a compromise to go with a vertical shaft. Because it is going to have a triple hydraulic pump attached to it.
I made a few phone calls and ATV engines are not that easy to get. Plus it would be a lot of retrofitting.
/ who makes the biggest EFI small engine? #8
Can you list the pump and its requirements?
/ who makes the biggest EFI small engine? #9
Check out the surplus supply store that advertises on this site... they have a Kubota diesel around 47 hp, for less than $4000.00.
I don't have the specs on the pump handy right now, but a smaller engine will run the pumps, but I want to be able to add other stuff later like a PTO.
that would be sweet, but it's a little big to fit in what I need. Plus almost nothing comes with it, and after everything was purchased, it would be well over my budget. But that's a very impressive price.
/ who makes the biggest EFI small engine? #12
Just go snatch the motor out of a Mini Cooper. Check out the motorcycle salvage yards. Some of those Crotch rocket bikes that outlived the driver might be cheap sources.
2011 Ford F750 Dump Truck (A62613)
2011 Ford F750...
2004 Cadillac Eagle Ultimate Hearse, Eagle Coachbuilders, Hearse Collector Special (A63688)
2004 Cadillac...
CASE TR340B SKID STEER (A64279)
CASE TR340B SKID...
2018 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2018 FREIGHTLINER...
2006 Hummer H3 4X4 SUV (A61574)
2006 Hummer H3 4X4...
2017 Cadillac Federal 70IN Limo w 27466 Miles, Premium Federal Coachwork, Luxury Transport (A63689)
2017 Cadillac...
