Who knows about stacked-block retaining walls?
   / Who knows about stacked-block retaining walls? #1
Sodo
Elite Member
Cascade Mtns of WA state
Kubota B-series & Mini Excavator
I'm putting up a stacked block retaining wall (6x17x12") blocks.
25 ft long, 7 courses, 42" high.
It's going up against an embankment of geotextile layers.
The lower 3 geotextile lifts are (very) sandy soil.
The dark layer is sandy topsoil.
Inn the end I'll just slope soil down to the 42" top of the wall.
Do I need tiebacks to the wall blocks?
Can I backfill it with sand?
You can see a test-stack of 7 blocks.
   / Who knows about stacked-block retaining walls? #2
By the look of the picture, your wall is not very long. I would put some tieback in just a cheap insurance. Is there any drainage issue in that location? My buddy didn’t put enough in and had a 4’ wall start to move in one of our Pineapple Express events.
   / Who knows about stacked-block retaining walls? #3
I used 'Perry Blocks' for my grade retaining wall for the grade change on my Clearspan truss arch building, however, they are very heavy and require a substantial machine to even move them.
Perry Blocks are what they use on the highway for concrete dividers and can be physically interlocked as well. The ones I purchased weigh about 3000 pounds per block.
   / Who knows about stacked-block retaining walls? #4
I thought they usually put crushed rock below and behind a retaining wall.
   / Who knows about stacked-block retaining walls? #5
If these are just dry stacked, what keeps them from sliding apart under pressure ?
   / Who knows about stacked-block retaining walls? #6
Your geotextile looks impressive!!!
The main reason for retaining walls to fail is water building up behind them. The water creates pressure, adds weight and loosens the soil. Another issue is when there is water behind the wall and the ground freezes. The ground expands and moves the wall. When the ground thaws, the wall remains in the moved location and either fails or is a lot weaker.
A drainage pipe at the bottom solves a lot of future issues. Rock is used between the soil and the wall so water will drain to the bottom and then exit through the pipe. Weep holes do this for smaller walls, but it's not as effective as a perforated pipe. Remember, the holes for the pipe go on the bottom.
Anything up to 4 feet tall generally doesn't need any engineering. Just stack them and be done.
Usually, the first row is buried in the ground to lock the entire wall in place.
   / Who knows about stacked-block retaining walls? #7
Eddie is right about drainage. If you go a few blocks high you don’t usually need tie backs but yours looks high enough you do.
   / Who knows about stacked-block retaining walls? #8
I do alot of excavation for retaining walls for a local company that specializes in retaining walls.
First...not sure what you mean by tiebacks. If its what I think.....thats where you use the geo-grid sandwiched between the blocks and runs behind the the wall and ties into the dirt.
Sand is not a good choice for backfill. It moves, settles, and retains water which is a freeze-thaw problem.
Here in Ohio, we call it #57 limestone. That is whats to be used. Its a uniform washed and screened stone....roughly the size of marbles (~3/4"). Not sure what its called in other parts of the country.
The "footer that the wall sits on is usually filled with ~8" of #57 and compacted. Wall stacked on top of that....backfilled with #57's and drainage at the bottom as well.
Depending on the height of the wall...1 or 2 blocks are usually burried. Keeps the bottom of the wall from pushing out.
Given the overall cost and labor of the project, doing it right adds very minimal cost in comparison to having to do it right later
They tip back one inch for every 6” up.
Thanks very much for all the suggestions and wisdom.
As you can see I’m building this from old blocks, and not solely because they’re cheaper. They’re almost “not” cheaper because of the physical labor to get them. But I didn’t have to pay 10% tax either. Including other reasons for it to look like it was done “long ago”.
It would have been wise to sandwich some geotextile flaps between the layers, leave them hanging out there for the retaining wall but that’s a first-timer for ya.
For tiebacks I was thinking of driving rebar rods and then figger a way to attach to the blocks.
I don’t have space for a drain pipe at the bottom. Have to put it at the 3rd course. There could be water here if my driveway drains “go unmaintained”. I think everyone knows that driveway drains eventually ALL “go unmaintained.”
The bottom row can’t kick out because there will be a paver-floor against the house holding it. And if what I read about geotextile soil retention is true- the bank won’t push. What do you guys think about that? Have any of you observed geotextile lifts behavior (or failure) over “years”?
   / Who knows about stacked-block retaining walls? #10
If these blocks are rectangular, you might get some tie back by setting some of them lengthwise. Weep holes and rock backfill will help drain water.
2002 CATERPILLAR D6M HIGH TRACK CRAWLER DOZER (A52709)
2002 CATERPILLAR...
Adams 6 Ton Fertilizer Spreader (A56435)
Adams 6 Ton...
2014 Bolens 11A-020W765 20in Push Mower (A55973)
2014 Bolens...
24ft T/A Flatbed Trailer (A55787)
24ft T/A Flatbed...
LOT: Assorted Hammers (A59076)
LOT: Assorted...
LOT: (40) 14 Oz. Tubes of Red Lithium Complex NLGI #2 Grease (A59076)
LOT: (40) 14 Oz...
