Who do ya call when your neighbor's waste pipe won't get it out?
   / Who do ya call when your neighbor's waste pipe won't get it out?
Here are a couple of pictures
Pictures are great, sorry about cellphone pictures
Jim
   / Who do ya call when your neighbor's waste pipe won't get it out? #22
Stick a potato in it. That would solve your part of the problem anyway.
Seriously though. That is very strange looking. I can't evebn imagine how what that hooks to or why.
If I could get up there, I would like to use some of that expanding foam in a can, it sticks like iron when wet
Shh
   / Who do ya call when your neighbor's waste pipe won't get it out? #24
That is seriously wierd looking. Glad you psoted the pics, theyc ame out allright.
   / Who do ya call when your neighbor's waste pipe won't get it out? #25
Just go up to his door and when he comes out,tell him your tired of smelling his ####,and you demand satisfaction,and slap him with your glove,,[make sure you bring a second to wittness this],,,than,,well thats as far as I thought now,,,but the duel should be with deadly weapons,,deer rifles would be best,,but I think thats his choice,,you better hope he don't decide pocket knives,,but chances gotta be taken here,,,thingy
   / Who do ya call when your neighbor's waste pipe won't get it out? #26
Methane is an explosive gas; an ignition source could lift that house off its slab! :eek: Hummmmm, now lets think! :rolleyes:
   / Who do ya call when your neighbor's waste pipe won't get it out? #27
MrJimi said:
Is that possible? It is near me and everytime they flush toilet it stinks big time, should there be a trap like under a sink to prevent odor from escaping?
I would like to plug it if thats what it is Shh
Jim
After looking at your pictures, I am sure that is what the problem is, the second vent coming up does not meet code as it is not venting high enough. This is what is providing the smell. There is no trap on a toilet other than the water in the bowl. The trap is designed to keep the sewer gas out of the house, not the smell from escaping to the outside world.
   / Who do ya call when your neighbor's waste pipe won't get it out? #28
I agree with Dumbdog that does not look up to code (too small and looks low). Building inspector may be able to help you. Any plumbing requires a permit and inspection around here. In the first pic you can see what looks like the original vent further up the roof. If that small pipe on the outside of the building is also a vent then it must be a repair for another problem. I'm not a plumber but I when I built my house I did my own plumbing to code.
   / Who do ya call when your neighbor's waste pipe won't get it out? #29
I thought EVERYTHING with a drain required a vent pipe for proper functioning.
If he only has one big vent pipe he might have problems and thus his "fix". Since its low to the ground it can smell. Like I said before, I could smell gas when on my old roof in the city. A few times I got a whif if the wind was just right and I was in the yard. His needs to be higher.
Later,
Dan
   / Who do ya call when your neighbor's waste pipe won't get it out? #30
Depends on the building code. When I built my cabin, which had to meet all local codes, a independant vent was not required for every drain nor did it have to go through the roof. I tied my 2 sinks, toilet and tub into one large vent pipe that ends in the attic with a vent valve on it.
To test the system I filled the tub and both sinks, then opened the drains and flushed the toilet at the same time. Everything drained rapidly.
Some people are a little nervous about having the vent pipe end in the attic, but as the inspector said, if it has backed up that far you already have bigger problems than poo in your attic. But, the valve prevents anything from coming out anyway.
UNUSED LANDHONOR LHR-RF24 RATCHETS & TOOLBOX (A54757)
UNUSED LANDHONOR...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
2017 Ford Explorer AWD SUV (A55758)
2017 Ford Explorer...
Pull-Behind 66in Smooth Drum Ballast Roller (A51691)
Pull-Behind 66in...
Galvanized Livestock Gates - (6x Total Gates) (A55218)
Galvanized...
2023 BOBCAT T66 R-SERIES SKID STEER (A52705)
2023 BOBCAT T66...
