White Smoke
/ White Smoke #1
johndeereg
MD
Cub Cadet 107
For the past month, my 175 hydro made a little white smoke at times when first started up, but usually it would go away pretty quick. Today I started it up after it had been sitting un-used for a few weeks. There was quite a bit of white smoke that lasted a few minutes before it went away. Should have cleared the bugs away haha. After using it a little, I stopped it. Later I started it again, and it had a good amount of smoke, but not the same as the first time today. Anyone know what's going on and is it something not too costly to repair?
thanks
/ White Smoke #2
Is the white smoke coming out the exhaust? In general, white smoke is oil smoke. You may have oil seeping past the piston rings. I am not familiar with your machine. Some engines just "use oil", even from day 1. (Chevy engines have that reputation.) If this is a new event, that is progressing, then it may be a costly repair, in time. Make sure you keep a watch on the oil levels.
Maybe someone else can help you with diagnostics to determine "where" the oil is coming from.
/ White Smoke #3
If the smoke clears in short time, then probably intake valve valve seal, or either valve guide.
/ White Smoke
Yes, the smoke is coming out the exhaust. In the past it smoked and would be cleared up in 20 seconds, maybe a minute tops. This weekend, it smoked for a couple minutes, then it went away. If it's a valve seal or guide, is this a problem that will eventually "break", making the mower un-useable? It's leaf season, so I'm hoping it makes it to winter haha.
203201 (A60429)
203201 (A60429)
CATERPILLAR D9T CRAWLER DOZER (A64279)
CATERPILLAR D9T...
2023 Globe Trailer GTDD30236 36ft. 75yd. T/A End Dump Trailer (A61573)
2023 Globe Trailer...
John Deere 7230 (A62180)
John Deere 7230...
1350 gal Tender Trailer (A66285)
1350 gal Tender...
Ford F800 (A63689)
Ford F800 (A63689)
