White Smoke
/ White Smoke #1
johndeereg
MD
Cub Cadet 107
For the past month, my 175 hydro made a little white smoke at times when first started up, but usually it would go away pretty quick. Today I started it up after it had been sitting un-used for a few weeks. There was quite a bit of white smoke that lasted a few minutes before it went away. Should have cleared the bugs away haha. After using it a little, I stopped it. Later I started it again, and it had a good amount of smoke, but not the same as the first time today. Anyone know what's going on and is it something not too costly to repair?
thanks
/ White Smoke #2
Is the white smoke coming out the exhaust? In general, white smoke is oil smoke. You may have oil seeping past the piston rings. I am not familiar with your machine. Some engines just "use oil", even from day 1. (Chevy engines have that reputation.) If this is a new event, that is progressing, then it may be a costly repair, in time. Make sure you keep a watch on the oil levels.
Maybe someone else can help you with diagnostics to determine "where" the oil is coming from.
/ White Smoke #3
If the smoke clears in short time, then probably intake valve valve seal, or either valve guide.
/ White Smoke
Yes, the smoke is coming out the exhaust. In the past it smoked and would be cleared up in 20 seconds, maybe a minute tops. This weekend, it smoked for a couple minutes, then it went away. If it's a valve seal or guide, is this a problem that will eventually "break", making the mower un-useable? It's leaf season, so I'm hoping it makes it to winter haha.
2002 Freightliner FS65 School Bus, VIN # 4UZAAXAK02CK16471 (A65563)
2002 Freightliner...
2013 HINO 338 26FT BOX TRUCK (A59905)
2013 HINO 338 26FT...
2018 VERMEER BC1000 XL PORTABLE WOOD CHIPPER (A63276)
2018 VERMEER...
New/Unused Landhonor8ft x 10ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
2000 Ford Windstar Van (A61574)
2000 Ford Windstar...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2020 CHEVROLET...
