Which would you chose?
/ Which would you chose?
ArtVandelay said:
Good post. I agree for the most part, but I believe Kubota does make tractors up to 103 PTO hp also. And I am sure Kubota's larger tractors stack up very favorably against Deere's of similar PTO hp.
Art, 103HP is considered pretty small now that big iron goes up past 500HP.
100-500+ HP is a lot more range of tractor size than 20HP-100HP.
When there's a big job to be done, names like DEERE, CAT & CASE/IH reign supreme, not Kubota. Kubota can't even compete.
However, Deere can and does very well at competing in the 30-100 HP range. However, as much as it pains me to say, Kubota is superior to Deere in the 30-100HP range with a few exceptions, of course. I like that K has their own engines & drivelines made in-house. Their quality is undeniable. It is rare to see anyone get burned or get a lemon from K.
/ Which would you chose? #23
FWIW I'd vote for the L4610 HST, Low hours, setup with R4's, probably a bit easier to trailer round than the others as well. And its closer to you, seems like the better deal to me if you give up a few HP, and of course if you are comfortable with the HST option.
I've owned a Kubota before, have an old L175 that just wont die but its hardly a modern Kub by any means, and I have never sat my hiney in a Deere, not even in a dealer lot, nor have I checked out any of the newer Kubota models. They both always seemed to be priced at a premium to the other brands I was comparing them with, but with the choices you presented I would still stick with the L4610.
/ Which would you chose? #24
Builder said:
Roy,
I'm thinking you live north of Manchester, MD where the L4610 and the Deere 5300 are for sale. Aren't you in the York,PA area?
I'm just SE of York. Manchester is about an hour drive...maybe a bit more.
Manchester is just south of Hampstead on MD Route 30 (PA Route 94), I think. I've been through there more then once, but it's been a few years.
It's definately the most sensible purchase. If I knew how much more tractor the M was than the L, it'd be easier to know. They're within a few HP of each other. Something tells me the M is a much stronger & heavier piece.
/ Which would you chose? #26
You could go to the Kubota website and look at the specs. If the weight of the "M" series is considerably more then the "L"s, that would be a pretty good indicator.
So, where are you at, Builder?
/ Which would you chose? #28
Builder,
One thing that adds cost and probably weight to the M4900 is the final drive. M-series final drives are planetary. L-series, to my knowledge (??), all have spur gear final drives. Planetary has been the defacto standard for Ag tractors for some time; heavy, rugged, quiet and expensive. Spur gear drives are simple, inexpensive, compact and noisy. I've never seen a debate comparing their reliability or strength. Properly engineered, I suspect either design can comfortably take anything the tractor dishes out.
Would be good to hear from someone who knows.
Bob
Bob_Young said:
Builder,
Bob
Thanks, Bob. You're right about the rears being heavier. The M-4900 is a good 800-1,000 lbs heavier than the L4610 from what I'm reading.
/ Which would you chose? #30
Builder you know you want the M4900:D , so get that sucker. There's a large tree removal company right down the road, and that's all they use is M4900's, I think they have three and one MX5000. They are all well used and we're talking large amounts of hard wood and timber. I asked one of the forman at the gas station about a month ago, how do they hold up, he replied "they are the only one that will". For what it's worth...Clay
Clay, you're soooo right. It's the one I want, now i just need some more $$$. You know how it is, there's never enough $$$ for the stuff we need for work.
The endorsement of the M4900 really means a lot. That's great feedback! ;)
/ Which would you chose? #32
I know just what you mean;) ! I have A wife.;) Clay
/ Which would you chose? #33
Bob,
I TOTALLY disagree that the under 50 hp line is not JD's focus. I think they do a great job with their compacts. I have owned now five of them myself and have not had a bad one yet. They offer features that are not seen in many (or any) other makes. I am not dissuading one from looking at Kubota, they have been doing solid compacts for a long time, but I take some issue with the thought that JD line of compacts is somehow an afterthought. JD knows many tractor users use the compacts and they sell a lot of them. Even my dealer, who is a big ag dealer that sells quite a number of larger machines, says the compact JD's make up a large portion of his yearly sales. I think Roy answered the question about "rebadging" well. JD compacts are for the vast part NOT rebadged machines. My tractor has only a Yanmar engine, with the rest of the tractor made/assembled in Augusta, GA. If anything, over recent years JD has moved the manufacture of many of its models to that facility. The example of the Yanmar made JD's would be the "90" series which are solid, powerful, simple machines that have been made by Yanmar for JD. These machines have been popular and high-margin sellers for JD, so I doubt they say a reason to change them or their point of origin. I would say that JD makes great compacts, just as Kubota deserves more credit for it larger machines.
John M
