Miller 211 might be fine for light sheet metal repairs, but it won't weld 3/16 metal. We got one at work last year and it got used for the first month and has not been used since. Even while turned all the way up and slow travel speed it won't penetrate very well. We returned it to the welding supplier we bought it from and they tested it and said it was working as it should. The 212 or 252 would be a better bet in my opinion. We have 2 252's and a 350P and just ordered another 350P. Only me and one other person use the 350P but everyone else uses the 252s and likes them and makes decent welds from all skill levels.
I have been looking at welders for while. Checking out the sponsors also. If I choose a millermatic, which would be a better choice, the 190 or the 211? hjt
I've had Millermatic 211, 3 years now. I use mostly .030 70s6 wire, it's good for light duty work, 1/16-1/4", .023 for body work/exhaust pipe. On steel that's thicker than 1/4", with a few inches to weld I leave a gap and go/weave vertical up. When buying a mig welder, I suggest getting a knurled feed roll for it, size bigger contact tip then the wire, felt wire cleaner, anti-spatter/weld jelly.
What wire are you using?
I dont like or use knurled rolls but I only use solid wire. No issues with V-groove. knurled will foul up a liner quicker
Normally one would use a U groove for aluminum but if you can get way with a V, Cool. As far as gas, 75/25 works for most. Add 3% O2 you can get into spray mode so to speak but I don't like to use O2 in any welding. ( Praxair has Stargon ) . I like 92/8 because I use Pulse and Twin Pulse. Short arc like most of you do works well too with this gas.. But, The newer inverter machines from all over the place are tuned to run straight CO2. I have some imported welders that do not spatter with CO2 providing you know what you are doing with gun angle and stick out. If you do know how to lay a bead, you can expect good spatter free welds with CO2 for 1/3 the cost of C25. It's all about saving money. I am lucky enough to not have to pay for my gas so I go high argon which is above 90%. If you really don't care about a little extra cost, 90/10 - 92/8 is great. 98/2 for SS. Europe and Asia are eons ahead of the USA in welding technology and all they use is CO2..Like I said, There are some lower cost inverters on here and out there that run CO2 very well. Even New transformer machines will of course struggle with CO2 as they are 1970's USA technology ie: miller 252 types.Hey in welding, what ever works. I'd use V-grove for aluminum welding, but on solid or flux core wire, .030-.035 I like a knurled roll on the bottom driver, use a lot less feed roll pressure, similar to life, sometimes there's just to much pressure. Then now and then and again, here and there and after a while, I blow the liner out.
You may wanna read up on specs if not familiar with the machines before bashing them.Miller 211 might be fine for light sheet metal repairs, but it won't weld 3/16 metal. We got one at work last year and it got used for the first month and has not been used since. Even while turned all the way up and slow travel speed it won't penetrate very well. We returned it to the welding supplier we bought it from and they tested it and said it was working as it should. The 212 or 252 would be a better bet in my opinion. We have 2 252's and a 350P and just ordered another 350P. Only me and one other person use the 350P but everyone else uses the 252s and likes them and makes decent welds from all skill levels.
Yes, and the 211 is rated to 3/8in. Shield Arc tried mine out when I first bought it he was easily welding 1/2in. But of course he doesn't know what he is doing... probably just got lucky. :laughing:You may wanna read up on specs if not familiar with the machines before bashing them.
The only differences between 211 and 212 are duty cycle , spoil size and 120-230V flexibility.
The 212 will not weld thicker metal!
Sent from my iPhone 5s 64Gb using TractorByNet
