...Expect more reality TV guys.
That'll work. Less time in front of the tube, more time fiddling with my tractor and cars and maybe even...reading...
That'll work. Less time in front of the tube, more time fiddling with my tractor and cars and maybe even...reading...![]()
The oil in there is as clean as that being pumped to the filter. The accumulated debris is in the filter media. Clean off the outside of the filter case and then punch a hole in the edge of the end of the can and let drain into a clean container.
larry
The oil being pumped to the filter is exactly as clean as the oil in the filter on the pre filtered side, as I said. The oil goes thru a filter thousands of times. If the filter were routinely filtering out much it would fill up and bypass or else block the system within a very short time. So the difference between the oil on the 2 sides of the filter media quickly reaches a near zero value after any event that dirties the oil with particulate. Or else the system fails, giving a clue.The oil on the 'dirty' side of the filter is not as clean as that entering the pump because it hasn't been filtered yet. In fact, it is probably the dirtiest oil in the entire machine. The media will trap the debris until flow stops, then a significant amount of debris migrates away from the media and disperses into the unfiltered oil. That's why a machine with a plugged hydraulic filter often has some flow at startup inspite of having cold, thick oil. As flow drives the debris back into the media, it becomes plugged all over again. When considering filter volume, there is more dirth oil outside the media than there is clean oil within it.
Remove the filter and discard it and the oil it contains. It is penny wise and pound foolish to do otherwise.
If that were true, there would be no need for filters of any kind. You really need to think about that.The oil being pumped to the filter is exactly as clean as the oil in the filter on the pre filtered side, as I said.
That migration back into the oil when flow stops is extremely small. The effect of full filter system blockage you describe is due to the pleats closing up in the filter under constant high suction, and then reopening when idle for awhile.
larry
Thats laughable. Check your reading comprehension.If that were true, there would be no need for filters of any kind. You really need to think about that.
I have, but I didnt shake it up 1st. [[Sure is - and I didnt say it]]I did. Now you go pour out a used hydraulic filter. [[The notion that ALL contaminants are permanently affixed to filtering media is naive]], and that's being charitable.
