Which way does a filter flow
/ Which way does a filter flow #12
That'll work. Less time in front of the tube, more time fiddling with my tractor and cars and maybe even...reading...:eek: :D:D
And life will be improved!
/ Which way does a filter flow #13
He-he. I kinda figured that if you asked a question like that, the actors were still on strike and you're not working and have a lot of time on your hands.
If you remove your filter and pour the oil into a clean pan, you will see a lot of little specs of debris. Now, imagine all the little ones you can't see. It's not worth the 2 quarts of oil to take the risk.
/ Which way does a filter flow #14
The oil in there is as clean as that being pumped to the filter. The accumulated debris is in the filter media. Clean off the outside of the filter case and then punch a hole in the edge of the end of the can and let drain into a clean container.
larry
The oil on the 'dirty' side of the filter is not as clean as that entering the pump because it hasn't been filtered yet. In fact, it is probably the dirtiest oil in the entire machine. The media will trap the debris until flow stops, then a significant amount of debris migrates away from the media and disperses into the unfiltered oil. That's why a machine with a plugged hydraulic filter often has some flow at startup inspite of having cold, thick oil. As flow drives the debris back into the media, it becomes plugged all over again. When considering filter volume, there is more dirth oil outside the media than there is clean oil within it.
Remove the filter and discard it and the oil it contains. It is penny wise and pound foolish to do otherwise.
/ Which way does a filter flow #15
Now if you get a flamable liquid pump, a filter head, an extra filter and a large tank then plumb it up so it will recycle the oil, you can filter out the impurities. But will still have the water. So you will need to set up a distillation column to get the water out. Will need to be stainless and have pressure reliefs so it won't blow up, etc. Then the additive package has to be renewed, but you will want to know how much of each to add, so you will need an analysis done. I figure you can get all that in place for just about $2000. Oil analysis will be about 20 bucks plus postage for each go round.
How much oil are you wanting to save and what return on investment are you looking to get?
/ Which way does a filter flow #16
The oil being pumped to the filter is exactly as clean as the oil in the filter on the pre filtered side, as I said. The oil goes thru a filter thousands of times. If the filter were routinely filtering out much it would fill up and bypass or else block the system within a very short time. So the difference between the oil on the 2 sides of the filter media quickly reaches a near zero value after any event that dirties the oil with particulate. Or else the system fails, giving a clue.
That migration back into the oil when flow stops is extremely small. The effect of full filter system blockage you describe is due to the pleats closing up in the filter under constant high suction, and then reopening when idle for awhile.
larry
/ Which way does a filter flow #17
If that were true, there would be no need for filters of any kind. You really need to think about that.
larry
We disagree.
It is a safe bet I will NEVER drain a spin on filter and pour the contents back into whatever system the filter is protecting.
/ Which way does a filter flow #18
Thats laughable. Check your reading comprehension.
/ Which way does a filter flow #19
I did. Now you go pour out a used hydraulic filter. The notion that ALL contaminants are permanently affixed to filtering media is naive, and that's being charitable.
Get over the fact that we disagree on this. It happens.
/ Which way does a filter flow #20
I did. Now you go pour out a used hydraulic filter. [[The notion that ALL contaminants are permanently affixed to filtering media is naive]], and that's being charitable.
I have, but I didnt shake it up 1st. [[Sure is - and I didnt say it]]
KJ K0720 7'x20' Metal Gate (Deep) (A60463)
KJ K0720 7'x20'...
2018 HINO SA (A58214)
UNUSED FUTURE FT-CL100C HYD CLAMP GRABBER (A52706)
UNUSED FUTURE...
Year: 2014 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: Plate: Body Type: 4 (A55852)
Year: 2014 Make...
2021 FORD RANGER (A60736)
2021 FORD RANGER...
2019 Ram 2500 4x4 Crew Cab Pickup Truck (A60352)
2019 Ram 2500 4x4...
