Grapple Which type of grapple is best suited for...
   / Which type of grapple is best suited for... #141
.....Curved bottom time tips would be my preference but I haven't heard anyone with straight bottom tines complain.
Straight works for me. With some sticks in it, and you tilt it, moving forward to get more, they slide up against the front teeth, that are angled up, and stay in the grapple.
   / Which type of grapple is best suited for... #142
I would buy the Wildkat if and only if they have switched from 4x4x0.125 to 4x4x0.25 for the top tube. 3/8" mild steel is all you need for the bottom tines and upper arm. I think that is currently the best bang for the buck but that top tube issue needs to be fixed. Curved bottom time tips would be my preference but I haven't heard anyone with straight bottom tines complain.
If the price was acceptable from a dealer I would happily own a WRLong 48" OBG2. I would not personally want an RBG style as I think the clamshell style grapples are not as versatile as well as being more expensive.
I haven't seen much about the Titan 48 but it looks fine. If EA made a 48 I would have confidence in that one too. Gator used to make a good 48 too but I don't know if they are in business anymore.
The Wildkat was my first choice initially but it sounded as though they have some SSQA issues. I will have to call them and ask about the top tube size.
   / Which type of grapple is best suited for... #143
The Wildkat was my first choice initially but it sounded as though they have some SSQA issues. I will have to call them and ask about the top tube.
I would be surprised if they have ongoing SSQA dimension issues. Trouble is that different tractor FEL QAs can be different too. I know my Kioti QA is much narrower than any other. I can still mate with a standard SSQA but there are large gaps left and right so implements can slide. So long as they don't pop off it shouldn't be a big problem.
   / Which type of grapple is best suited for... #144
I went with the NAI 48" Light Duty Root Grapple.
My main decision factors were:
> Tractor is a Kubota L3540 w/ bigger loader (i.e. not too big)
> Maximize lifting capacity for moving logs
> Decent design & build quality
> Reasonable Price
It was $820 plus shipping (which was a decent chunk to Calif). I don't recall the weight, but it's one of the lightest. It has greaseable pins for all of the pivots.
I first used it to move brush to the burn pile and it worked great. I have also used it to move large oak logs and it lifts more than I expected. Like all other grapple owners, I'm very happy with it. :thumbsup:
   / Which type of grapple is best suited for... #145
2) does anyone know if Wildkat changed the gauge of 4x4 tubing used from 0.125" to 0.25"?
I bought one from them last fall. I was aware of the issues posted here. I sent them some of the pictures and asked about the top support tube. They said they have fixed the issue. I live about 40 miles from their factory so I went there to purchase the 66" grapple from them. I have not had any problems other than the quick attach bracket location made the grapple a bit loose on my Kubota Quick Attach. That has also been mentioned on this site. I welded a couple of 1/4" x 2" steel plates to the bottom support brackets - problem fixed. Works as advertised.
HP
   / Which type of grapple is best suited for... #146
> Reasonable Price
Looks nice. Great price. The back is a bit shorter than mine which explains the slightly smaller max opening.
Happy grappling.
   / Which type of grapple is best suited for... #147
> Reasonable Price
Caspar, when did you buy yours, I recently got a quote for $1016 plus $145 shipping. I noticed the grapple pictured in the link you posted has 7 bottom tines. Is the one pictured the 48" I thought the 48" only had 5 tines. I also noticed some photos so the bottom tines are straight while other are curled up, is this an option.
   / Which type of grapple is best suited for... #148
I know a little bit about what goes into a grapple. It is a heck of a lot of work to build one. I don't see how some of these companies are selling them so cheap. They have to be cutting some corners. Where are they if you have a problem with it?
   / Which type of grapple is best suited for... #149
Good question. However, unless you buy a WRLong from a local dealer, you pretty much have to deal with repairs with local resources yourself. Nearly every grapple manufacturer is hundreds of miles away and getting anyone to help is pretty difficult. Shipping costs, especially returns, are prohibitive as the grapple needs to be palleted and picked up. On the good side, not much goes wrong once you get them set up as they are pretty simple devices and a local hydraulic shop plus a local welder can do pretty much anything the original manufacturer can do. I would imagine that even WRLong just has the local dealer make any necessary repairs. When I bent the tips of my upper jaw tines on a big rock, I just took the upper jaw off, threw it in the back of the car and took it to a local gas station to have them straighten and reinforce the tips. Probably should just have made the repair myself but I didn't have a torch to heat the tips with at the time.
   / Which type of grapple is best suited for... #150
I did not literally mean were are they. I meant would they give you a bunch of run around and would the problem ever be resolved. I would rather deal with somebody reputable.
2017 John Deere 6120E (A53317)
2017 John Deere...
2023 Caliber Trailers GH840MST 40ft 6 Ton T/A Gooseneck Flatbed Equipment Trailer (A55852)
2023 Caliber...
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A55302)
Kubota SVL65-2...
2022 Club Car Tempo Cart (A55853)
2022 Club Car...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
2016 John Deere 326E (A47477)
2016 John Deere...
