Which tractor?
/ Which tractor? #1
strick
This is not meant to start a war on brands.. I just would like a little info on the pros and cons of each tractor. I have one acre of sand and I need a little tractor to do some grading moving dirt around and weed cutting. I'm considering a new tractor Kubota 7510, New Holland TZ24DA, and Kiote CK20. all are priced close to each other. HELP!
strick
/ Which tractor? #2
Strick,
I have a B7100 that is an older version of the B7510. I love it and would not trade it for any newer tractor, but it is paid for. I like the Kubota because in the 15 years that I have had the tractor, I have replaced one glow pug and one battery. It starts first time, every time when the bigger tractors will not.
When I decided to buy a larger tractor, I went to my dealer that carries both Kubota and Kioti. After talking with the owner, the parts manager, and the service manager, I found that they all own Kubotas although they could get the Kiotis at a bigger discount. That made my decision. I have no experience with the NH
You will find advocates of all brands on here. With good maintenance, about any of them will give good service until you get tired of looking at them. Look around and see what the professional landscapers are using. They can't afford to have down-time.
Best of luck on your decision.
/ Which tractor? #3
Well, you got apples and oranges there. The TZ24DA is a sub compact, while the TC24DA is a larger framed compact which compares more directly to the size and capabilities of the other two you mention. Given the nature of your work, you may well be served best with a sub compact like the TZ or it's red clone from Case. Be sure to check the Massey and Kubotas BX models for comparison. Very capable machines, all. Lots of info and owner feedback on all these models can be found in their respective forums. Best advice is to spend some reading time there getting a handle on the basic differences, then approach owners about your specific questions.
/ Which tractor? #4
Strick,
For me, I looked at FEL capacity and 3pt. capacity and then drove the models that I was interested in. I ended up with a Kubota B7500 and have never looked back. That said, there was not a NH or Kioti dealer near me, so my opinion is VERY biased. If you are interested, I just posted a project with my B7500 in the owning and operating forum - Tree Removal.
Have fun shopping.
Greg
/ Which tractor? #5
Welcome to TBN. You say you have 1 acre of sand. What kind of sand, where? That could make a difference in what you want to buy because of the differences in weight between models.
I have a sandy type soil here in NE Florida, and find that my CK20 is just fine in almost all but the wettest conditions, and it weighs about 600# more than the Kubota, which gives me a little better traction. For moving dirt around, leveling, pulling trees, digging stumps (with backhoe), etc., it has been a GREAT tractor. I have the HST model. I like the platform style of the CK better than the ladder frame of the Kubota, more comfortable, more room etc.
I suspect, if you never plan to do anything more than you stated, you could go with a sub cut like the Massey, kubota, or NH, but the CK20 is a small-frame CUT with plenty of capability for when you realize there are lots more jobs you want to do than you're thinking of now! John
/ Which tractor? #6
are they all equiped the same? the tz is sub compact whereas the other s are compacts.
/ Which tractor?
Thanks fellas for all the input. I live in N. California. The sand has a hard base and I can easily drive around in 2wd with my pick up without worrying about getting stuck. I still cant make up my mind on what to get. I've even been considering a used japanese tractor but they are all in the 7-9K range for 18-24 HP 4wd under 800 hours. I'm getting quotes in the 11500 range for all three of the tractors I mentioned the NH TZ24DA the Kubota B7510 and the Kioti CK20. All three are real nice tractors. The NH comes with the hydrostatic tranny. The other two are manual. I'm starting to figure that If I'm going to spend between 7-9k for a used tractor that does not have 2 PTO's and all the other little luxeries that a much newer model has then I might as well put 7K down on a brand new tractor and take advantage of the zero financing for 1 year or 2.9 percent for 2 years. Plus I'll be getting a warranty. I have a NH/Kubota dealer 25 minutes from my house...they have been there 30 years and they are real nice so as of now it's between the Kubota and the NH. I'm not sure I'm reading the lift capacity right of the loaders between the Kubota and the NH. The NH reads 657 at max bucket height and the kubota reads 1655 at LP. Is the Kubota rated for that much more?
Strick
/ Which tractor? #8
<font color="blue"> The NH reads 657 at max bucket height and the kubota reads 1655 at LP. Is the Kubota rated for that much more? </font>
The NH is a SUBcompact tractor and the Kubota is a COMPACT. You are comparing apples and oranges here. Gerard
/ Which tractor? #9
</font><font color="blue" class="small">( I might as well put 7K down on a brand new tractor and take advantage of the zero financing for 1 year or 2.9 percent for 2 years. )</font>
Kioti is offering 0% for two years until March 31. May extend that again.
Most loaders capacities are measured at the connection point of the bucket or lift pins/points. A "comparable" New Holland will generally lift more than a Kubota loader. Depending on model of course.
Why not check out the CK20 with HST? Only about $800 more, you'll never miss that over the years of enjoyment and ease of operation. John
/ Which tractor? #10
strick
You mentioned in your post that you have been checking out certain brands of tractors. You need to check out the Zetor tractors. Zetor makes a very nice tractor. Zetor tractors per size of PTO horsepower you buy is as heavy as any tractor on the market weight wise. One really important thing about Zetor tractors is the price. If you find the right Zetor dealer, you can buy one of these tractors cheaper than the brands of tractors that you stated in your post.
Cabinholler
/ Which tractor? #11
<font color="blue"> I'm not sure I'm reading the lift capacity right of the loaders between the Kubota and the NH. The NH reads 657 at max bucket height and the kubota reads 1655 at LP. Is the Kubota rated for that much more?
</font>
strick, you are reading the numbers wrong. The loader manufacturers don't make things easy on us when they publish the numbers but you have to be VERY careful when you look at loader specs. If the loader is measured at the pivot point it will be rated higher than at the center of the bucket, and the lowest rating is at the bucket lip. That said, they have different elevations that they do the measurements and those change too. A bucket measured at 12" above the ground will have a higher rating than one measures at full lift height. So you really have a series of things to check. If you want to compare 2 loaders, look at the full lift height rating, then see if it was measured at the pivot, the bucket center, or the bucket lip. Once you know that, then compare it to the same measurments on the other brand.
As for the comparison between the New Holland and the Kubota, I'd guess they are just about equal but I've not looked them up. NH is known for very strong loaders, the Kubota loaders are good, but not rated as high as some of the other brands. As you are comparing a smaller NH to a slightly larger Kubota, my intuition says both are probably close enough that you'd not notice.
By the way, the HST transmission is great. I'm totally spoiled and would never go back.
/ Which tractor?
OK.. I'll look more closely. I realize that they call the NH a subcompact tractor however it looks to be vary close in size to the kubota and Kioti. The NH hydrostatic is marked at the same price as the manual Kubota and Kioti. I guess I'm going to have to drive all three again and see which one I like the best. What about Industrial tires in the sand. Remember this is sand with a firm base. I like the wider base they provide for stability. I'm looking at 4WD's. Thanks again you guys are great.
strick
/ Which tractor? #13
With one acre of sandy soil, I really think one of the sub-compacts would best suit your needs. Of the three you listed, the New Holland is the only sub. The Kubota sub-compacts are the BX series, and they've sold about a kabillion of 'em... they're a proven machine. Other sub-compacts include the Massey Fergussen GC series and the Cub Cadet 5000 series.
The Kioti is larger and heavier than the sub-compacts, but still a very nice tractor. It would certainly accomplish what you want to do, but for the size of your lot, I'd say go with a sub.
/ Which tractor? #14
TBrown is correct on the sizing issue. Kioti does not make a sub-CUT. The CK is a fine tractor but it is larger and heavier with lower hp than the NH. The Kubota you are looking is one of their smallest CUTs but it is also not a Sub-CUT, it also has less hp than the NH. The major difference between a small CUT and a SUB-CUT is probably going to be found in the ground clearance and the capacity at the 3pt hitch. However, given your property size and type, it doesn't sound like you'd be using large implements anyway. I think you will find that the Sub-CUTs can do an amazing amount of work despite their small size. There are many very happy customers on TBN that do some pretty amazing things with small tractors and they seem able to do anything a bigger tractor can do (granted a bit slower) while still getting into tight places that even slightly larger tractors can't get to.
Regardless of the tractor you choose, I would recommend the HST transmission, it is really nice to use in small places, it is faster to use with a front end loader, and it is easier to use when grass cutting.
/ Which tractor? #15
don't know if this would be an important issue for you, but one of the differences from sub to compact is the ground clearence.
/ Which tractor? #16
</font><font color="blue" class="small">( they've sold about a kabillion of 'em... )</font>
Tbrown,
How many zero's are there in one kabillion again? /forums/images/graemlins/smile.gif
Hypernix /forums/images/graemlins/grin.gif
/ Which tractor?
Right now I'm leaning to the NH. I test drove one today. The dealer is giving me a good price as compared to other places I've checked. You are right in that the ground clearance is not as good as the kubota but it should be fine for were I'll be using it. I like the Kioti and the Kubota but their manuals and the dealer wants another 1K for hydrostatic in those models. The NH 3 point hitch is the standard type were as the kubota compact has a limited 3 point hitch. I'll keep you guys posted as to what I end up getting. Saw a landscaper today driving around on a NH /forums/images/graemlins/cool.gif
Strick
RoGator and Terragator Manuals (A63117)
RoGator and...
1999 Bell B25C 6x6 25 Ton Articulated Dump Truck (A61572)
1999 Bell B25C 6x6...
Iranch High-End Tricycle (A64119)
Iranch High-End...
Heavy Duty Booster Cables (A59230)
Heavy Duty Booster...
17in. Tooth Excavator Bucket (A64194)
17in. Tooth...
Caterpillar 345B/BL Excavator Service and Parts Manuals (A63117)
Caterpillar...
