3-Point Hitch Which Top Link Hole to Use - an illustrative model
   / Which Top Link Hole to Use - an illustrative model #21
I doubt a person will see a measurable difference in the amount of weight the lower link arms will lift regardless of which position the upper link is pinned in. But to me it is a mute point anyway due to my implements all have drivelines so I want the implement as flat as possible thru the entire lift/lowering range.
If a mower or snowblower were setup like OP's last two examples, the driveline u-joints would have a shortened life span due to the tractor out put shaft and implement input shaft not being kept somewhat parallel to each other.
It makes a 10% difference, give or take. It is CERTAINLY noticeable.
But most implements paired for the machine size never comes close to the lift capacity of the machine regardless of hole selection. Which is why most people dont care.
But put a boom pole on, or a set of pallet forks on the machine, and it matters.
   / Which Top Link Hole to Use - an illustrative model #22
My new Kubota looks to be the opposite of my Ford 3000. So is yours hinged on the top or bottom. Using the hole closest to the hinge point makes least sensitive in draft mode.
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55852)
2006 iDrive...
2016 FREIGHTLINER CASCADIA TANDEM AXL MID ROOF SLEEPER TRUCK (A59905)
2016 FREIGHTLINER...
2016 Chevrolet Malibu Sedan (A59231)
2016 Chevrolet...
CATERPILLAR 305 CR EXCAVATOR (A60429)
CATERPILLAR 305 CR...
2012 NISSAN 110 FORKLIFT (A55745)
2012 NISSAN 110...
CAT 289D3 (A58214)
CAT 289D3 (A58214)
