Which Tire Chains
/ Which Tire Chains #22
Thanks TallTale, I will check them out.
When my 4330 comes, the dealer said I should put the factory wheel weights (300 lbs per tire) on the rears and fill them with Calcium. This would give me max traction that I need to push that heavy snow from the drifts up and down those 12 degree slopes on my driveway road. The chains will be a big plus.
Does anybody have any opinions on the dealers recommendation or a cheaper source for wheel weights?
/ Which Tire Chains #23
Don't quite understand what you are pushin' with ...FEL? If so, get the chains, fill the wheels, and forget the wheel weights, get a Chinese snow blower for the 3ph ...more weight, and you may just decide not to push ...just my 2 pence
/ Which Tire Chains #24
I will be pushing a FEL (the heavy duty model). I don't think I want to drive backwards with a blower, but I will look for a good price on a front blower if these Denver winters look like they might be with us for a few years.
I might add a plow blade to the FEL that I can easily remove and put back on as others have mentioned on this site.
I did not know too much about the wheel weights. The Ford 535 I know have with a FEL is extremely light on the rears and won't go thru 1/2 in of snow without spinning the tires, even with chains ( a 2WD ).
I don't want that L4330 to be light on the rears especially around my hills. I might need to add a blade or boxscrapper on the rear for balance and I can use them in the summer to dress the road.
/ Which Tire Chains #25
The loaded tires should give you close to a thousand pounds of extra weight. As JoeL has said I would not fool with the wheel weights. The total weight of your tractor with loader will be around 5,400 lbs, you should be able to move some pretty big snow drifts with your 4330, especially with a good set of chains on.
/ Which Tire Chains
Well, UPS delivered my chains from tirechain.com last night. Laid them out and tried to lay them over the tire. Quickly realized that wasn't going to work, so I spread them out on the ground, hook a chain to them and threw it over the tire. Drove forward slowly and they went right on. The are a little loose right now so I have spend some time getting them tighter.
Took them out for a spin at about 9 last night and plowed our very drifted (2-3ft in some places) driveway with no problems. The rear of the tractor will still "crab" just a little with the blade in its most angled position when plowing on a side slope but nothing like it did without the chains. I'd end up pointing the other direction on occasion before the chains. Usually I plow in 2nd range and before the chains it would spin if you had too much snow behind you. Now it will pull until the tractor almost stalls without spinning a wheel. Drop down into low range and it just motors on along.
I'm glad I went with the 2 link design because I think the 4 links would have mostly disappeared into my R4's treads. Well worth the extra money.
I'm going to fiddle with them some tonight and try to get them positioned better over the treads and tighter overall. Proabably cut off or wire up the extra links in the side chain too so they don't catch on something. Clearance is pretty good in most areas on my TC33DA. The only places that are close are the lower 3pt arms and where the fenders attach near the ROPS. Both places still have about 1-1 1/2 of room now.
/ Which Tire Chains #27
Thanks Oleozz. When you mentioned filling the tires giving 1000 lbs extra weight, did you mean all four or just the rears only?
Wvrocks. Those chains you got from tirechain.com, were they the 2link Ladder/Vbar ladder chains that you mentioned in your first post?
/ Which Tire Chains #28
Just the rears Catman. The R1's on the 4330 are the same size as the tires on my Kioti. It took 94 gallons of Rim Guard to fill my two rear tires and that should add up to about 1,000 lbs of extra weight. I'm not sure of the capacity of the R4's.
/ Which Tire Chains #29
Thanks Oleozz. I will tell my dealer today. I'll forget the weights.....
/ Which Tire Chains #30
Just an extra thought, I would buy the chain tensioners that tirechain.com sells, they area inexpensive and keep the chains good and snug.
/ Which Tire Chains
Catman1, yeah I got 2 link ladders. I didn't get the V-bars on mine because I was concerned about damaging my garage floor. I probably should have went for them to get maximum traction but the regular chains are a marked improvement.
Btw, I have all of my tires filled. I didn't know that until I took one front wheel off a few weeks ago. Much heavier than I expected it to be. Guess the dealer just filled them all, I only asked for the rears though.
/ Which Tire Chains #32
Yes, thanks for reminding me. By the way, I am originally from PA. Moved to Colorado in 85.
As long as the Steelers are winning, my mother makes spaghetti, meatballs, raviolis and all the good stuff. When they are losing everything stops.
This has been a very bad year for eating!!!!!
/ Which Tire Chains #33
Joel4330 and Oleozz
I have went with the front snow blower that Kuboto makes. This will make it easier on my wife who will have to use it when I am out of town and a local place to take of it. If it goes down, dealer with lend me one. With the chains from tirechain.com and filling only the rear R4's I hope I have good balance.
I am concerned that, with a FEL on the front or the blower on the front, I might not have enough weight in the rear direction. Do I need to do something about that, like a blade or boxblade on the 3pt for balance. A blade could wipe the snow left from the blower and give rear balance.
My only experience with this is with my Ford 535. With the FEL on the front, the rear tires are really, really light.
Any opinions?
/ Which Tire Chains #34
When using the front-mounted blower, its weight is on the skids, on the ground, so counterbalance not required, just good traction and your chains should provide that ...on the other hand, if I were you and had a back blade, I would have it on, as well, probably facing backwards ...unless it were wider than the blower and unless I had some tight maneuvering required.
2012 Mini Cooper Hatchback (A64557)
2012 Mini Cooper...
2018 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A65053)
2018 CATERPILLAR...
2006 INTERNATIONAL 7600 6X4 T/A DUMP TRUCK (A66091)
2006 INTERNATIONAL...
2022 Tesla Model 3 Long Range AWD Sedan (A64557)
2022 Tesla Model 3...
HONDA Plate Compactor (A64557)
HONDA Plate...
2020 Chevrolet Traverse SUV (A64557)
2020 Chevrolet...
