Which spool valve?
/ Which spool valve? #1
Fish1102
Sylva,NC
Kubota L3700SU
Hey guys, first post. Thanks ahead for all the info. I've been reading alot from the forums on rear hydraulics, power beyond and top and tilt kits. I'm really interested in adding a top and tilt kit to my Kubota L3700SU. I have basic understanding of hydraulics and thanks to the forums, have figured out the power beyond concept. I am in the process of gathering parts for a top and tilt kit for my tractor and was looking through all the spool valve at the Surplus Center. Any recomendations on which 2 Spool valve would be best for my particular tractor? Thanks again.
/ Which spool valve? #2
Maybe this one. I prefer stacking valves, easier and cheaper to add more valves in the future if-when needed. I would get both valves with the float function. Always nice to have float when needed vs needing it and not having it. ;)
/ Which spool valve? #3
Agree.
Total Price
2 SPOOL SV VALVE OPEN CENTER W/POWER BEYOND
Item# 9SV-2-Y
Components:
- SVW1DD1 (DA CYL SPOOL W/DETENTED FLOAT POSITION) #PSV D SECTION
- POWER BEYOND OUTLET SECTION #SVE22
- SAE8 RELIEF INLET SECTION #SVI15
- 2 SECTION TIE ROD KIT #660401002 $290.95 in
$290.95
Subtotal
$290.95
Thanks a million guys.
/ Which spool valve? #5
Agree.
Total Price
Item# 9SV-2-Y
Components:
$290.95
Subtotal
$290.95
J_J, do you think these valves are okay for a L3940 with total hydraulic flow of 14.7gpm. The valves are rated at 12gpm nominal and 16gpm maximum.
Thx.
/ Which spool valve? #6
You will not notice much difference as most tractor owners don't run their tractors at max rpm anyway.
You don't have to get stacked valves if you only need one spool with float. A monoblock valve will work. , and less expensive.
/ Which spool valve? #7
Thx.
You are only running the implement pump flow through any of the remote valves. For your tractor that is 9.8 GPM. You would have no problem at all.
I typically recommend stacking valves because it is sooooooooo easy to add more valves at a very low cost in the future. Once a person realizes how easy and efficient hydraulic functions can be, they often want more. JJ is correct though, a monoblock valve is less $$$ if that is all that you will ever need. ;)
Thanks again guys. Brian, I just ordered my top & tilt kit from you. I am getting ready to order the valve you guys suggested and was just wondering if there was anything else I needed from the Surplus Center before I ordered. I was thinking of getting my hoses made locally, reason being, I will mount valve and then get measurements for hoses.
/ Which spool valve? #10
Thanks for the order. Thumbsup: Did you decide on a double or triple valve setup? My double is $330 and a triple is about $400. I can do hoses cheap and fast. ;) The valve can go out tomorrow if need be. :cool:
/ Which spool valve? #11
One other thing, when you measure for hoses, if you can, use some 3/8" air hose and run it in the path you you feel suites you best. That will be a match for the hydraulic line size and get you an exact length. If not available, then see about using some water hose. ;)
Double.. I didn't realize you sold the valves also, I thought I read on your website that you didn't. I would have ordered it when I ordered the kit.
/ Which spool valve? #13
Sorry, we were a little slow at changing that on the website. Should be changed now. I'm sure that you will be fine with what you are getting. ;)
No problem Brian. Does that price include shipping also? Thanks.
Lockers (A62613)
Lockers (A62613)
UNUSED SDLANCH 14' PARTING IRON GATE (LION SCENE) (A64281)
UNUSED SDLANCH 14'...
2010 Cadillac CTS Sedan (A61574)
2010 Cadillac CTS...
2014 Massey Ferguson 8650 Tractor (A63111)
2014 Massey...
Challenger 425B/445B/455B Tractor Service Manuals (A63117)
Challenger...
CASE INTERNATIONAL 3330 HI-CYCLE SPRAYER (A63291)
CASE INTERNATIONAL...
