Rotary Cutter Which new cutter???
/ Which new cutter??? #43
Here are a few pictures from my BH27 84" 3" capacity
Looks like it has more clearance than the unmodified. But nothing like what the mods show little scared about that. Its much easier to take more off than to but it back especially with wood, steel is a little easier. I could see going to far seriously impeding cut quality as this will disrupt the vortex under the deck and probably let out much larger unprocessed material. I would probably bet that the opening clearance is a balancing act between too little discharge (clumping as a result) and to open resulting in little mulching
I'd venture to guess that the woods is probably not that much different behind the rubber than the others. Dumb question but Did the blades get put on upside down or did they forget to form the cutting edge? What your describing does not sound typical. I would not want to be anywhere near where that is operating. I ordered chains for mine because I've been hit by indirect (bounced) shrapnel thrown from a cutter
Good luck with your endeavors hope your buddy is successful is his quest.
/ Which new cutter??? #44
Dang it, now I am now curious and need to go down to the barn tomorrow and look at mine behind the guards.
2716SFL (A61567)
2716SFL (A61567)
2014 Ford Transit Connect Handicap Van (A61573)
2014 Ford Transit...
2016 Yanmar VIO25 (A60462)
2016 Yanmar VIO25...
2014 Dynapac CP142 9 Wheel Pneumatic Roller (A62679)
2014 Dynapac CP142...
2024 CATERPILLAR 68" HYD 4IN1 BUCKET (A62129)
2024 CATERPILLAR...
2016 CATERPILLAR 416F2 BACKHOE (A62129)
2016 CATERPILLAR...
