Which grease to use?
   / Which grease to use? #1
magnatic
Bronze Member
Southern Ontario
2006 BX2350
I've always thought that wheel bearing grease was superior to extreme pressure grease or multi-purpose grease. Yet while reading a tube today, it indicated that wheel bearing grease "may" be used for "certain" farm applications.
Which is the best for tractor, loader, mowerand snowblower use?
Thanks.
   / Which grease to use? #3
Kubota manual says NLG1 2 grease for ball bearings and roller bearings.
Look for that spec (nlg1 2) and you should be good to go.
   / Which grease to use? #4
Wheel bearing grease is most suitable for high temperatures. Dont go nuts over which grease, a 5 gal. can of Molly grease, its EP and a pump to reload your gun is all that is needed.
   / Which grease to use? #5
I like Valvoline Crimson Red. For off road applications. Find it at NAPA. Philip.
   / Which grease to use? #6
For general purpose grease, I use Sta-Lube Moly-Graph. The worst thing you can do is mix grease types. If your application uses lithium base grease, stay with lithium base.
   / Which grease to use? #7
We started using this on our new JD round baler last year and use it on about
everything now.
thumbnail.asp
John Deere Multi-Purpose SD Polyurea Gun Grease - TY6341
   / Which grease to use? #8
I used Mystik JT-6 Hi-Temp NLGI #2 but I found out that it belongs to old Hugo Chavez. Now I don't know what to use. I won't finance him though.
Great Plaines 2400 Tt (A50514)
Great Plaines 2400...
2007 GREAT DANE CONVERTER DOLLY (A51222)
2007 GREAT DANE...
Electric Scissor Lift (A50322)
Electric Scissor...
2018 John Deere R4038 Self Propelled Sprayer, (A50657)
2018 John Deere...
New Kivel 4200 lb. Skidloader Forks (A50774)
New Kivel 4200 lb...
1996 Fertilizer Tender Trailer (A50514)
1996 Fertilizer...
