Which engine is used in the Yanmar YB20 excavator?
   / Which engine is used in the Yanmar YB20 excavator?
Jaap,
Glad to help.
Is the German manual for the YB20 in PDF to share?
Yes, I would like to see how the plow fits on the forks too.
I have a hard copy (of not very good quality, but it is readable). I will see if I can scan it in the near future, and share it.
The lift height is what I noticed. Pic.4 my guess is the forks are around 10' then another 8' lift section. That could come in real handy also. Esp. with a pallet type deck to work on.
Yes in the past I have put a large pallet (3 x 1 meter) on the forks and used it as a platform to do work at a few meters above ground level.
   / Which engine is used in the Yanmar YB20 excavator? #13
A little safer is an IBC tote. Remove the plastic tank, use the cage as a platform lift on your forks.
Also, the IBC cage can be used as a Carry-All.
Jaap,
Glad to help.
Here is a low resolution version of the scan of the German Manual, attached to this reply. The original scan is 31 Mb so I cannot upload it here due to the upload size limitations.
  • Yanmar Diesel-Kompaktbagger YB20 Betriebsanleitung - Service Anweisungen LowRes.pdf
   / Which engine is used in the Yanmar YB20 excavator? #15
Thank you so much!
   / Which engine is used in the Yanmar YB20 excavator? #16
I recently bought a 1996 yb401w...a 3.8t yanmar wheeled excavator, I'm really struck by the build quality.
   / Which engine is used in the Yanmar YB20 excavator? #17
oh it has the beefy engine too, 4TNA78T with a turbo.
Jaap,
Glad to help.
   / Which engine is used in the Yanmar YB20 excavator? #19
You are very crafty, I like it.
   / Which engine is used in the Yanmar YB20 excavator? #20
"Crafty" in the ingenious fabricator sense!
All the best,
Peter
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
30pc 3ft. x 8ft. Red Polycarbonate panels (A55758)
30pc 3ft. x 8ft...
2019 Ford F-750 Reel Loader Flatbed Truck (A56858)
2019 Ford F-750...
2020 Deere 50G (A53317)
2020 Deere 50G...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
Gas Pump Artwork (A55758)
Gas Pump Artwork...
