Which attachment would you buy?
   / Which attachment would you buy? #21
The attached photo shows pallet forks that are at auction tomorrow. I haven't seen them in person, but they look kinda heavy. Too heavy for my tractor?
   / Which attachment would you buy? #24
I have a similar set (see photo). They are fine for tractors with lift capacity over 1500lbs.
   / Which attachment would you buy? #26
Those will not be to heavy for your tractor. They look like a very nice set of forks, if the price is right, I would bid on them.
Good luck. :thumbsup:
   / Which attachment would you buy? #27
FF117 said:
I'm thinking it's time for some new equipment, but can only get one. I have plenty of uses for each of these and have the required hydraulics. Here are the options:
1 - pallet forks. I borrowed some clamp on forks from a friend and found them useful for moving most brush and logs. I would like to get quick attach type instead of the clamp on though. Price $550-700
2 - top'n tilt. I've been wanting to get this for a while because I have some grading work to do around the pond and eventually around our house/driveway (plan to build in a few years). Price approx $500
3 - 48" Wildkat grapple. I wasn't considering this until recently when I found out you can get one of these for $600 + shipping. I would probably use it a lot for a while and then it would sit in the shed mostly. I seems like a pretty good price and I'm not sure how long that price will last.
So what would you buy?
I have heard more people over a long period state that pallet forks are one of the most useful implements. They may also be in my future. Good luck on deciding.
No luck. I set myself a limit of $500 on the forks and they went for $500, but I wasn't the bidder. I would've had to go $550 to get them. The other set (walk-through) went for $600. They looked pretty good, nice welds and they weren't too heavy, but there were only three width position adjustments. The other models I have looked at had at least five positions.
There is another auction next week with two more sets of these forks. It's a larger auction, so they probably will go higher, but I'll try anyway.
   / Which attachment would you buy? #29
thats a good price, i paid about $850 for mine when i bought them. Incl free shipping. Those pictures look like it was a stout unit.
I ended up getting these brand new "Stout" brand 48" forks for $425. They were listed as "light duty", but they have the exact same frame rails, quick attach plate, and forks as the "heavy duty" ones that I posted earlier. The only difference I could see was the backguard and steps on the side. No doubt the heavy set was nicer, but they were going for $600+ and I don't think the difference was worth it for me.
Since I've got the forks now I'll probably get TnT next summer, and next time my dad goes to North Carolina I might have him pick up a Wildkat grapple for me. I figure I won't need TnT until next spring anyway because winter is fast approaching and I won't have time to do any grading. Thanks to everyone for the opinions.
The pics are kinda crappy cause I took them with my cellphone.
   / Which attachment would you buy? #31
Now you will need a "Quick Spade". It is basically a massive shovel head that slips over the fork tips. Allows you to dig about 4ft deep. Not as effective as a BH but about 3% of the price. They actually work pretty well and using the forks you can shovel about ten times as much as you can by hand.:thumbsup: Cannot find my photos right now but if you search on my screenname and quick spade I'm pretty sure you'll find photos.
   / Which attachment would you buy? #33
As for the pallet grapple check this out-
Fork Grapple | Gator Attachments
I've been needing some forks so i might just get that and kill 2 attachments at once.
Not exactly the same as a grapple in terms of the type of work you can do. Great for moving logs though. Not sure what they charge but you could add a grapple arm to a set of forks for about $350 or so.
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2019 KOMATSU D155AX-8 CRAWLER DOZER (A60429)
2019 KOMATSU...
2019 CATERPILLAR  XQ35 GENERATOR (A58214)
2019 CATERPILLAR...
2014 Chevrolet Impala Limited Sedan (A59231)
2014 Chevrolet...
40' CONTAINER (A52706)
CONIBEAR EQ CO HYD SEED SPREADER (A60430)
CONIBEAR EQ CO HYD...
