Which attachment would you buy?
   / Which attachment would you buy? #21
The attached photo shows pallet forks that are at auction tomorrow. I haven't seen them in person, but they look kinda heavy. Too heavy for my tractor?
   / Which attachment would you buy? #24
I have a similar set (see photo). They are fine for tractors with lift capacity over 1500lbs.
   / Which attachment would you buy? #26
Those will not be to heavy for your tractor. They look like a very nice set of forks, if the price is right, I would bid on them.
Good luck. :thumbsup:
   / Which attachment would you buy? #27
FF117 said:
I'm thinking it's time for some new equipment, but can only get one. I have plenty of uses for each of these and have the required hydraulics. Here are the options:
1 - pallet forks. I borrowed some clamp on forks from a friend and found them useful for moving most brush and logs. I would like to get quick attach type instead of the clamp on though. Price $550-700
2 - top'n tilt. I've been wanting to get this for a while because I have some grading work to do around the pond and eventually around our house/driveway (plan to build in a few years). Price approx $500
3 - 48" Wildkat grapple. I wasn't considering this until recently when I found out you can get one of these for $600 + shipping. I would probably use it a lot for a while and then it would sit in the shed mostly. I seems like a pretty good price and I'm not sure how long that price will last.
So what would you buy?
I have heard more people over a long period state that pallet forks are one of the most useful implements. They may also be in my future. Good luck on deciding.
No luck. I set myself a limit of $500 on the forks and they went for $500, but I wasn't the bidder. I would've had to go $550 to get them. The other set (walk-through) went for $600. They looked pretty good, nice welds and they weren't too heavy, but there were only three width position adjustments. The other models I have looked at had at least five positions.
There is another auction next week with two more sets of these forks. It's a larger auction, so they probably will go higher, but I'll try anyway.
   / Which attachment would you buy? #29
thats a good price, i paid about $850 for mine when i bought them. Incl free shipping. Those pictures look like it was a stout unit.
I ended up getting these brand new "Stout" brand 48" forks for $425. They were listed as "light duty", but they have the exact same frame rails, quick attach plate, and forks as the "heavy duty" ones that I posted earlier. The only difference I could see was the backguard and steps on the side. No doubt the heavy set was nicer, but they were going for $600+ and I don't think the difference was worth it for me.
Since I've got the forks now I'll probably get TnT next summer, and next time my dad goes to North Carolina I might have him pick up a Wildkat grapple for me. I figure I won't need TnT until next spring anyway because winter is fast approaching and I won't have time to do any grading. Thanks to everyone for the opinions.
The pics are kinda crappy cause I took them with my cellphone.
   / Which attachment would you buy? #31
Now you will need a "Quick Spade". It is basically a massive shovel head that slips over the fork tips. Allows you to dig about 4ft deep. Not as effective as a BH but about 3% of the price. They actually work pretty well and using the forks you can shovel about ten times as much as you can by hand.:thumbsup: Cannot find my photos right now but if you search on my screenname and quick spade I'm pretty sure you'll find photos.
   / Which attachment would you buy? #33
As for the pallet grapple check this out-
Fork Grapple | Gator Attachments
I've been needing some forks so i might just get that and kill 2 attachments at once.
Not exactly the same as a grapple in terms of the type of work you can do. Great for moving logs though. Not sure what they charge but you could add a grapple arm to a set of forks for about $350 or so.
2015 CATERPILLAR 308E2 CR EXCAVATOR (A60429)
2015 CATERPILLAR...
Midwestern Industries MEV Screen Model MEV 5X10-2 (A56438)
Midwestern...
2017 FORD F350 XL 35' NON-INSULATED BUCKET TRK (A59823)
2017 FORD F350 XL...
iDrive TDS-2010H...
2018 ALLMAND MAXI-POWER 45 GENERATOR (A58214)
2018 ALLMAND...
UNUSED X-STAR ACS LOADER BOOM LIFT (A52706)
UNUSED X-STAR ACS...
