Which 4000
/ Which 4000 #1
Anonymous Poster
Epic Contributor
To start with, I have three acres of land, 2 are mowable, with a few dozen trees to get around, and one acre that I would like to finish (ie. remove small stumps,roots and rocks and landscape.) In the winter, my main use would be snow removal from approx. 2400sqft parking lot and 600 ft of driveway. My delemma unfolds as to which tractor to buy. I considered the JD4100 (feels just like my cub2185 too small). The 4200 seems perfect for my needs,(HST, MFWD, 60MMM, 420FEL w/HD bucket and 6' backblade. Dealer price $19,285 + tax. But then I read all this info on TBN and I'm thinking maybe 4300 or just sit still and wait for the 4010 series... WOW... Wandered around and looked at Kabotas... Test drove a 2910, it was ok. But just ok isnt worth $18900. What should I do? Very very confusing...
/ Which 4000 #2
Mike-
If the 4100 feels too small, then it probably is. I think the 4200 is a good choice and will do all you want it to. The 4300 will be a slightly better loader tractor, with its longer wheelbase and higher hydraulic pressure, but I'm not sure you need that. The 4300 also sits on larger wheels and tires than the 4200, giving it more traction, but at the expense of a higher center of gravity. The decision on the ten series, I think, depends on how much you're willing to spend, and how soon you need the tractor. - Stan
/ Which 4000 #3
Mike, unless cost is the critical factor I would suggest waiting for the 4000 ten series. The 4210 is rated 1 or 2 hp over the 4200. Additionally, there are some hydraulic control improvements and supposedly about 75 other improvements over the 4000 tractors. Of course we don't know yet was these improvements are going to cost but I think I would wait until the new tractors are officially released which we are told should be in November.
/ Which 4000
Mike
If I recall correctly, when you climbed aboard one the Kubota grand L (L3010, L3710) you liked the roominess and comfort. Did you get a chance to test drive one of them?
Tom
/ Which 4000
Hi Tom,
The only kubota I drove was the 2910. Dave felt that the 3010 was much to big, and it was overkill for what I needed it to do. I haven't driven the deere as of yet, but I am going to meet with Keith and talk to him about the 4210 and test drive the 4200. What do you seem to think about this new 4010 series? Do you think the cost will be very dramatic? Your opinion is greatly appreciated.
Mike
/ Which 4000
Deere4600,
My wife thinks I crazy now wanting to spend 20k. Do you think the price increase is going to change immensely?
Mike
/ Which 4000
Mike
Dave calls it the way he sees it..with a lot of experience; however if you insist on something bigger, he will sell it to you. HP wise the 3010 fits in between the 4200 and the 4300. JD is longer by about 5 inches but is almost 7 inches narrower than K. You have to decide whether you ever plan on doing something where lateral stability will become important. The 3 larger tractors weigh about 1000 lbs more than the 2910. I would think that this would provide more traction when moving snow. We don't get as much snow as some states but it certainly needs a lot of muscle to move snow around here. I talked to a JD dealer, not Keith, who told me that the 4x10 "improvements" were all very minor......something along the lines of a different bolt size, etc. I'm sure he was just trying to gloss-over the early short-comings of a new release..the 4000 series. However, if what he said is true, there should not be a big price difference from the 4000. The JD marketing types will certainly have their own opinions.
If you want to test drive my L3410, let me know.
It's all going to come down to what YOU are most comfortable with.
Tom
/ Which 4000 #8
I believe the Kubota 3010 is longer than the JD 4300. In the literature you will notice that Kubota lists length without the 3ph whereas JD lists it with the 3ph. The 3ph adds about 10". I'll check my brochures when I get home tonight. Also, I believe you are correct that the Kubota wheel spacing is maximally greater, but keep in mind that the 3010 has about 5 different rear wheel width spacing positions.
/ Which 4000
Glennmac
Yes, the K literature gives the length w/o the 3p, but my jd lit does not indicate whether the length is with or without the 3p. The width I used was the minimum width taken from the brochures.
Tom
/ Which 4000 #10
My 4200 is a damn fine rig ,for my own standards.
/ Which 4000 #11
Mike, I don;t think Deere will be able to pass along a huge price increase due to the fact they still have to compete cost wise with NewHolland and Kubota. Of course that assumes you compare the cost of the new ten series and the current series using the same equipment/options, etc. I would guess you might see an increase of about 2-3 percent. However, the new electro controlled hydrostatic transmission option on the ten series might be rather expensive. I haven't seen, nor has my dealer, any prices on this option. The other changes that Deere is talking about shouldn't result in a significant price increase. If Deere tries too big of an increase it will just drive more customers to the other manufacturers. The only way they will get away with it is if the changes make for a better tractor than the competition. Moving the 3rd hydraulic control lever (cable operated) next to the DSCV (hopefully a direct mount to the valve) is a nice improvement but both Kubota and Newholland currently have better controls for the 3rd hydraulic. I'm glad Deere made this change but they shouldn't increase the price substantially just to do what the competition is already doing. THe new electric operated Hydro transmission is a different matter. When I order my 4410 I will probably get this option. Again, if it is an improvement over the competition I don't object to paying a higher price.
/ Which 4000
Tom,
I would like to talk to you more about these tractors, and yes I would like to take a closer look at yours. Leave me a message.
Mike
/ Which 4000 #13
Is there going to be a 4110 model? Or, are they going to leave the 4100 as is? I had only heard about a 4210, 4310, etc.
/ Which 4000 #14
Mike -- Just a guess, but I can't imagine Deere would boost the prices much. Right now one of the major reasons they lose sales to Kubota and NH is the price point. I really liked the feel of the 4300, but the price (and some of the QC problems with the early units) pushed me into the Kubota L3010. I love my tractor, but sometimes, when moving heavy logs or loads of wet sand, I wonder how much of a difference the greater hydraulic capacity of the 4300 would have made...
Another point for those of you familiar with JD pricing...when the 4x10 comes out, will the prices of the remaining 4000 series drop to get them off the lot?
Pete
www.GatewayToVermont.com
/ Which 4000
<font color=blue>...will the prices of the remaining 4000 series drop to get them off the lot?...</font color=blue>
Hi Pete,
I don't think it will be any different than a automobile manufacturer releasing the next year's model... plenty of buyers will take the 1 year old brand new model off the lot to save an additional $500- $1000. dollars. Buyers are very unpredictable as you well know and do crazy things to save a buck on day one that may have cost them many $$$ to get there...
TBN may be a good example of a number of posters that have purchased one tractor over another to save a couple hundred dollars...without really thinking it through.../w3tcompact/icons/shocked.gif
I also believe, thousands of compact tractors will be purchased before the fact... they find a site like TBN that discusses the pro's and con's of each unit... so in essence they are not very informed and most don't have any idea of tractor pricing... {not like cars, with window stickers...}
Unfortunately, sometimes it ends up being whatever the market will bear on the unsuspecting buyer... /w3tcompact/icons/crazy.gif
2013 POLAR TANK 8,500 GAL ALUMINUM TRAILER (A67714)
2013 POLAR TANK...
2012 SPARTAN GLADIATOR FIRE TRUCK (A66091)
2012 SPARTAN...
2018 CHEVROLET IMPALA (A66091)
2018 CHEVROLET...
2009 IC Corporation PB105 School Bus (A68183)
2009 IC...
2017 CHEVROLET SILVERADO 2500HD (A65643)
2017 CHEVROLET...
2009 WESTERN STAR 4900 SF WINCH TRUCK (A67714)
2009 WESTERN STAR...
