Tiller Which 3PT tiller do you prefer?
/ Which 3PT tiller do you prefer? #41
<font color="blue"> I am not concerned even the JD681(81") tiller is 250 lbs lighter than the CCM 210. They have a 60 hp gearbox and CCM has 100 Hp gearbox. </font>
I undestand the reson that Belarus (Russia) and China and Turkey make casting thicker and heavier is to cover the imprefections in the material during the manufacturing process--JD and other Major manufacturers go in the oppisite direction because they use top quality input steel and spend more money on design. --Ken Sweet
Sweet Farm Equipment LLC *Used "Handy Hank" Antique Tobacco Primer $895*
/ Which 3PT tiller do you prefer? #42
</font><font color="blue" class="small">( ... the reson that Belarus (Russia) and China and Turkey make casting thicker and heavier is to cover the imprefections in the material during the manufacturing process-- )</font>
Technical info.
Most of gearboxes including tiller gearboxes are mostly grey cast iron or sometimes ductile cast iron. Steel cast is very rarely used in gearboxes. Grey cast iron is the cheapest, then steel cast comes. Ductile cast iron is the most expensive. Cast quality is the best in ductile cast iron. Then, grey cast iron comes. Casting steel is most problematic one. Anyway, all of these tiller gearboxes (and gearboxes of most of implements) are made of grey cast iron which is easy to cast and the cheapest. The gears inside are not cast; machined direct from the round standart materials. So, the quality of grey cast iron does not change from China to Italy to Turkey to USA. But the price changes. The cheapest cast is in China. Turkey cast iron price is twice more expansive than China. Italy's cast iron is 2-3 times more expansive than Turkey. By the way, the gears of CCM tillers (actually TURKAY TARIM tillers) are not made by TurkAy itself. Konya mfgs make it for TurkAy. Izmir, the city where they are located is more expansive city than Konya. Ps: People blowing here too much.
/ Which 3PT tiller do you prefer? #43
the local dealer that is selling recond yanmar tractors, also sells recond yanmar tillers, 48 and 52 inch for about $550..
i plan on looking at them...will let you know what they "look" like.
heehaw
/ Which 3PT tiller do you prefer? #44
I'm using a Wood's estate model on my BX23. I used it for the first time yesterday and was pretty pleased with it's performance. If I have any complaints, it would be the weight. I think a heavier tiller would be better. When hitting rock or large roots, the tiller bounces like crazy. I would think additional weight would help to counter that. Then again, it may be operator's error too! LOL
/ Which 3PT tiller do you prefer? #45
Nomad,
I was worried about you because, we had not seen you posting lately. I thought you were maybe learning Spanish since you now have some South American customers. Even your Turkish countrymen have asked me where is Nomad? I am happy to see you are healthy and back on TBN. /forums/images/graemlins/tongue.gif
/ Which 3PT tiller do you prefer? #46
How are the Agri-Cutter attachments?
What brands should I stay away from?
Thank you,
Greg
p.s. I'm a new tractor owner and appreciate any info.
/ Which 3PT tiller do you prefer? #47
I just bot a Bush Hog TRS 62 tiller this spring (Italy mfg /forums/images/graemlins/grin.gif) Its a shear bolt model and despite hitting some pretty big roots, it just keeps on tilling. I'm happy with its ability to chop up and bury various "green manure" crops. The OM and tech support from BH are first rate too. /forums/images/graemlins/wink.gif
Natty B.
/ Which 3PT tiller do you prefer? #48
Dean
I have an ortolan L-100 tiller on the back of my kubota b7200hst. It is similar in power and size as your 7510. Their web site (www.ortolan.net) says they are the OEM for some american relabelers. The specs on the gearmore brand labeler are the same as the ortolan.
I can not compare the ortolan to any other 3 pt tillers. All I can tell you is it is a HUGE improvement over walk behind tillers. I find that the 39 inch L100 is rated for a 17-40 hp tractor and I do bog down my b7200 on our tough california clay. I believe a 48 inch, sufficient to cover the wheel width, would be too much for my motor.
The only thing I will restate that others have said is ... do get a slip clutch. You will be glad you did.
/ Which 3PT tiller do you prefer? #49
Gearmore & Ortolan are the same tillers MFG by Ortolan.
/ Which 3PT tiller do you prefer? #50
I did find a name on my "mystery" tiller. It is a Maschio. It seems very well built and relatively inexpensive. People have been talking about HP needed to turn a particular tiller, and I have to agree that most PTO tillers require a large amount of HP. I just traded my 84" Maschio tiller for a more reasonable 72" model. I've tried with three different tractors, and 50hp is not enough for an 84" tiller! You can turn it, but not at much depth and at an extremely slow ground speed. The 72" seems to be the largest tiller that a 50hp tractor can turn.
/ Which 3PT tiller do you prefer? #51
Dargo,
If you notice on the CCM Tiller Page you will see recommended HP ranges. These HP ranges are based on experience and safe operation procedures. These recommendations are based on CCM scroll diameter, size of the tiller tine, tiller weight, and total number of tines on the tiller.
Wacker Neuson PT2 Water Pump (A59228)
Wacker Neuson PT2...
2014 Chevrolet Equinox SUV (A64557)
2014 Chevrolet...
2021 CATERPILLAR 299D3 XE SKID STEER (A65053)
2021 CATERPILLAR...
New/Unused Landhonor Gantry Crane (A65583)
New/Unused...
1974 Ford F600 Grain Truck (A63118)
1974 Ford F600...
2016 Ford Escape AWD SUV (A64557)
2016 Ford Escape...
