Where to put toolbox on little Kubota?
   / Where to put toolbox on little Kubota? #23
My Kubota M9540 came with a small toolbox behind the seat, but I added an ammo can that is mounted to the loader frame so when I take the loader off, I still have the toolbox on the tractor. I also modified the grill guard to be a chain box. I added a fire ext. to the ROPS.
   / Where to put toolbox on little Kubota? #24
Them ammo boxes work great;) here is where I mounted mine, not all that large but does hold the essentials :thumbsup: a Chain, few wrenches, screwdrivers short handle hammer, spare tractor pins, etc,etc,
   / Where to put toolbox on little Kubota? #25
No pics, but my CCY SX3100 is so compactly designed, there's hardly any place to mount even a narrow 30-cal ammo box. I've tried! I ended up using a section of angle iron bolted to a pair of existing holes in the top of the cross-bar behind the seat, above the PTO. Then I passed a pair of short 3/8 bolts through holes drilled in the angle iron into the side of the ammo can. The angle iron allows me to hang the ammo can on the back of the cross-bar so that the can is more or less suspended over and to one side of the PTO. This allows me to put the seat back as far as it'll go without bumping into the ammo can, but it also means I can't put anything too heavy in the ammo can. Not ideal, but it works, and I can easily remove the ammo can and angle iron, leaving behind no traces of the modification.
   / Where to put toolbox on little Kubota? #26
i've had to make angle iron brackets to mount tool boxes before too. when I added a rops to my ford 5000, the fender tool box couldn't fit anymore.. not enough fender either side.. so i made a double offset angle iron bracket and found 2 bolt hole sinthe trans bellhousing for it. worked great. mounts just like the one on my 7610S does.. esentially..
soundguy
   / Where to put toolbox on little Kubota? #27
Nice setup. can you put your tools under the seat in that kind of model?
John Deere 650K (A53314)
John Deere 650K...
UNUSED FUTURE CLG72 72" HYD CURVED LOG GRABBER (A57193)
UNUSED FUTURE...
2018 VOLVO EC480EL EXCAVATOR (A52707)
2018 VOLVO EC480EL...
2018 Ford Fusion Hybrid Sedan (A53424)
2018 Ford Fusion...
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
2018 Ford Escape SE AWD SUV (A55853)
2018 Ford Escape...
