where to position tractor on trailer?
   / where to position tractor on trailer? #21
I ordered a weight safe hitch last night and will use that for tongue weight etc. Looks like the trailer should be around 2500 pounds give or take. I'll use the steering wheel for initial positioning and fine tune it with the weight safe hitch.
I love mine. Expensive, but cheap when you compare it to the cost of the truck, trailer, tractor or whatever other cargo you haul.
Guessing often means overloading your hitch & rear suspension or setting yourself up for fishtailing. At some point you get a feel for it, hopefully before breaking something or a code brown. I got a feel for mine but still upgraded from a stand alone tongue scale I used a few times to the Weigh Safe. I spend the 5-10 seconds every time I have a load on to look at that dial. A few times I've realized I was far enough off I should restart the tractor & move it a bit.
golf cart (A56859)
golf cart (A56859)
20ft x 30ft Steel Carport (New/Unused) (A59225)
20ft x 30ft Steel...
2024 John Deere 331G Skid Steer w/ WARRANTY! (A59213)
2024 John Deere...
2017 WEILER P385 ASPHALT PAVER (A52709)
2017 WEILER P385...
3 HOLE FRIGIDAIRE FOOD WARMER (A58374)
3 HOLE FRIGIDAIRE...
2019 PETERBILT 579 (A58214)
2019 PETERBILT 579...
