Where to get weld on hooks?
   / Where to get weld on hooks? #21
R-enforcing the top lip of your "LA304 loader with 2" X 2" X 3/8" angle" Is going to be not strong enough go with 2x2x1/4" and the 1/4" plate underneath is not a bad idea either.
Steve
Kubota B7800
In my area of the country 3/8" is 50% thicker than 1/4" (2/8")!:confused2::confused2:
   / Where to get weld on hooks? #23
Absolutely weld some C-channel to the bucket top to stiffen, I did and there is no way my loader is capable of exerting enough force to bend my bucket top now.
Joel
   / Where to get weld on hooks? #24
I put some on my tractor and they are very usedfull when moving things around, on my profile i have a few pics you can see how i put mine on
   / Where to get weld on hooks? #25
Check out this site BXpanded.com they have a very different approach to a hook system. Pricey but well worth it.
   / Where to get weld on hooks? #26
McMaster Carr has them, mcmaster.com. However I welded regular grab hooks to my bucket thinking that maybe the holes might be helpful at sometime in the future. I ran a rod through the holes before I welded them fully so that the holes were in line with each other, then some multi-pass beads to form a good fillet.
   / Where to get weld on hooks? #27
i used harbor freight 3/8" (reg) hooks and cut the loops off the end.
works fine for me :thumbsup:
   / Where to get weld on hooks? #28
Now that re-enforcing looks quite substantial. Nice job!:thumbsup:
   / Where to get weld on hooks? #29
I took the easy way out and bought heavy duty 3/8 clevis grab hooks. ground a flat spot on the back of the hook and welded to the bucket. works great. that was my only alternative as I live at the end of the world and we don't have any sort of farm supply or tractor stores within 2 hours drive.:)
   / Where to get weld on hooks? #30
When I welded my hook I simply used regular 3/8 hook and ground off the small ring (or eye) and ground the back a bit to flatten it then welded it to my bucket.
About 10 years on it now and no troubles.
Oh. and I welded the hook to about a 3 X 4 X 1/4 flat and then that flat to the bucket as I wanted to spread the strain around a bit.
24" PIN ON BUCKET (A52707)
24" PIN ON BUCKET...
John Deere 5055E (A53317)
John Deere 5055E...
2013 Infiniti G37 Coupe (A55853)
2013 Infiniti G37...
Link-Belt 75X3 (A53317)
Link-Belt 75X3...
2018 John Deere 8320RT Track Tractor (A53485)
2018 John Deere...
BUSH HOG 2615 - 15' BATWING MOWER (A51243)
BUSH HOG 2615 -...
