Where to get weld on hooks?
/ Where to get weld on hooks? #1
bullet3z
Pa
I want to get weld on hooks for my FEL. Where is a good place to get? Also what is a good/safe size for a B3200 with the LA504 loader?
I searched and can only find the threads that show the hooks already welded on. I have not been able to find the threads that show where to get them.
/ Where to get weld on hooks? #2
/ Where to get weld on hooks? #3
As mentioned AW Direct has them or most local Tractor Supply Stores.
/ Where to get weld on hooks? #5
Most Kubota dealer have hooks in stock..might pay tad more but worth it.
I have never noticed them at TSC do you have a cat #?
I looked on the TSC website and could not locate them.
Also what is the best size and grade?
/ Where to get weld on hooks? #7
You want Grade 70, The 5/16" are very common for compact tractors.
/ Where to get weld on hooks? #8
I bought 3/8" Gr. 70 hooks for AWDirect because I have 3/8" log chains. I have not installed them as of yet, but plan on re-enforcing the top lip of my LA304 loader with 2" X 2" X 3/8" angle before welding on the hooks.
Just went to my local TSC and they do not carry weld on hooks. So it looks like I may have to order them.
I also need to get some chain. So I guess I need to match up the chain size with the hook size?
/ Where to get weld on hooks? #10
When I researched this last fall I found most people recommended 3/8" hooks as they can be used with both 3/8" and 5/16" chain.
/ Where to get weld on hooks? #11
Or you can just cut down the hardware store clevis or round hole hooks..Thats how Ive always done it. Maybe before the invented the weld on ones.
/ Where to get weld on hooks? #12
My local tractor store has them but he's not a TSC store just a tractor dealer. Like Bedlam said, You could buy the grab hooks with the eye and just cut them flat so you could weld them on. I've done that before.
/ Where to get weld on hooks? #13
I have allways ordered them from awdirect, I get the 3/8 weld hooks, they are gr70 and forged they also already come with a chamfer for welding. I also weld a 1/4 min thick plate to the bucket before attaching the hook.
Thanks for the help with this. I am going to check 1 local place to see if they stock them. If not I will order them online in the 3/8 flavor.
/ Where to get weld on hooks? #17
Agri-Supply has them too, that's where I ordered mine from. I went ahead and got the 3/8" grab hook since it will work with 5/16" and 3/8" chain. If you get the 5/16" size, obviously you'll never get a 3/8" chain in it. I don't ever plan on stressing it to the point that something will bend or break. Then again, I guess no one ever plans on bending or breaking something! :D
/ Where to get weld on hooks? #18
You might want to consider adding a receiver hitch to the center of your bucket with a hook on top and two more, one on either side of the bucket. Seeing that you will be reinforcing the top lip and welding on the pelican hooks adding receiver hitch is very useful for many attachments. I use mine all the time.
R-enforcing the top lip of your "LA304 loader with 2" X 2" X 3/8" angle" Is going to be not strong enough go with 2x2x1/4" and the 1/4" plate underneath is not a bad idea either.
[URL=http://s802.photobucket.com/albums/yy306/radly53/?action=view&current=P3091361.jpg][/URL] [URL=http://s802.photobucket.com/albums/yy306/radly53/?action=view&current=P3081354.jpg][/URL]
Steve
Kubota B7800
/ Where to get weld on hooks? #19
I will second the receiver hitch. I put 3 hooks on mine. One on each end and one in the center. The only place I have found weld on hooks was online and at a little mom and pop hardware store.
Hard to see the hooks but there is one on each corner and one on top of the hitch.
Chris
/ Where to get weld on hooks? #20
Chris
It appears the bucket where the receiver is bent down somewhat, is that caused from use of the hitch?
Kivel Quick Hitch Mini Skid Steer Attachment (A61572)
Kivel Quick Hitch...
EZ-GO GAS GOLF CART (A63276)
EZ-GO GAS GOLF...
2005 Ford F-150 Ext Cab Pickup Truck (A61573)
2005 Ford F-150...
2025 Polaris Ranger Premium (A60462)
2025 Polaris...
2008 Yale GLP070VXE 6,500lb Propane Forklift (A61572)
2008 Yale...
Caterpillar C18 Industrial Diesel Engine - Serial N8F01109 - Arrangement 385-7728 - Pump Takeout (A63689)
Caterpillar C18...
