Where to buy tabs
   / Where to buy tabs #1
handirifle
Central Coast of CA
Massey Ferguson 1010
I'm modifying a trailer from ag use to on the road use. I'll be adding some side rail stakes and building short and tall sides. I also want to weld some hold down tabs along the sides, to secure rolling loads. On the front I used the pieces I cut off the original draw bar hitch. They were 1" thick with 1 1/4" holes in them.
I checked the local welding shop to see about some other tabs, and they said they would have to fabricate them, at $45 min labor.
Does anyone sell something like this premade? I'd like 1/2" or thicker, with 1" hole or larger, so I can weld them to the sides of the trailer.
Other suggestions also welcome.
Also, where would I find those nice spring loaded chain hooks for the safety chain? They look like a weedless fishing hook, a big one though:thumbsup:.
   / Where to buy tabs #3
Perhaps some U bolts. You could also bend some 1/2 in rebar in a U shape and weld to the sides. El cheapo.
   / Where to buy tabs #4
Truck and Tow has just about everything you could possibly want for your project. Just search their site.
I you join their email list they will give free shipping on your first order (a least they did in the past). That makes a considerable difference when shipping metal.
https://www.truckntow.com/default.aspx
   / Where to buy tabs #5
that actually works good.
we have a beat up tripple crown hd flatbed at work.. we did just that.. torch heted and bent some rebar around a 3" round pipeusing another pipe to slip the end into then bend around... worked great.. once painted shiney black, looks fine too.
soundguy
   / Where to buy tabs #6
I think I have some tabs like you describe at my shop. Will look when I get home tonight. Shipping may be a killer, do not know where you are located.
   / Where to buy tabs
Bill, thanks for the offer. I'm in Central Coast of CA, so a long ways off.
I like the rebar idea. been using that to make my fireplace tools anyway, might as well find a new use.
Cheap, is ALWAYS good, in my book.
   / Where to buy tabs #8
just make you a jig to bend them. we use a piece of 3/4" id pipe at a right angle to a piece of 3" od pipe.. slid the rebar ( 1/2" ) into the pipe a ways heated with smoke wrench with rosebud tip while a buddy curled it around the form ( 3" pipe" ). then we quenched them in a 5g pail and chop sawed them and did another.. went fast.. turned out good. ground the paint ont he frame with a 4.5" grinder.. vice gripped one at a time on and buzzed it in place with 6011/6013 root pass /top pass then hit it with matching paint.
soundguy
   / Where to buy tabs #10
i guess I've been lucky. I've picked up rebar scrap for years and never had a single issue welding with it...ever..?? and I'm certaintly no pro welder.. nor is my ac buzzbox anything special.. :)
soundguy
1986 John Deere 772B Articulated Motor Grader (A49461)
1986 John Deere...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2020 CATERPILLAR 326 EXCAVATOR (A51242)
2020 CATERPILLAR...
2015 Chevrolet Impala Sedan (A49461)
2015 Chevrolet...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A49461)
2021 Ver-Mac...
John Deere Hsld 2510 H Nh3 Applicator (A50514)
John Deere Hsld...
