Where to buy tabs
   / Where to buy tabs #1
handirifle
Veteran Member
Central Coast of CA
Massey Ferguson 1010
I'm modifying a trailer from ag use to on the road use. I'll be adding some side rail stakes and building short and tall sides. I also want to weld some hold down tabs along the sides, to secure rolling loads. On the front I used the pieces I cut off the original draw bar hitch. They were 1" thick with 1 1/4" holes in them.
I checked the local welding shop to see about some other tabs, and they said they would have to fabricate them, at $45 min labor.
Does anyone sell something like this premade? I'd like 1/2" or thicker, with 1" hole or larger, so I can weld them to the sides of the trailer.
Other suggestions also welcome.
Also, where would I find those nice spring loaded chain hooks for the safety chain? They look like a weedless fishing hook, a big one though:thumbsup:.
   / Where to buy tabs #3
Perhaps some U bolts. You could also bend some 1/2 in rebar in a U shape and weld to the sides. El cheapo.
   / Where to buy tabs #4
Truck and Tow has just about everything you could possibly want for your project. Just search their site.
I you join their email list they will give free shipping on your first order (a least they did in the past). That makes a considerable difference when shipping metal.
https://www.truckntow.com/default.aspx
   / Where to buy tabs #5
that actually works good.
we have a beat up tripple crown hd flatbed at work.. we did just that.. torch heted and bent some rebar around a 3" round pipeusing another pipe to slip the end into then bend around... worked great.. once painted shiney black, looks fine too.
soundguy
   / Where to buy tabs #6
I think I have some tabs like you describe at my shop. Will look when I get home tonight. Shipping may be a killer, do not know where you are located.
   / Where to buy tabs
Bill, thanks for the offer. I'm in Central Coast of CA, so a long ways off.
I like the rebar idea. been using that to make my fireplace tools anyway, might as well find a new use.
Cheap, is ALWAYS good, in my book.
   / Where to buy tabs #8
just make you a jig to bend them. we use a piece of 3/4" id pipe at a right angle to a piece of 3" od pipe.. slid the rebar ( 1/2" ) into the pipe a ways heated with smoke wrench with rosebud tip while a buddy curled it around the form ( 3" pipe" ). then we quenched them in a 5g pail and chop sawed them and did another.. went fast.. turned out good. ground the paint ont he frame with a 4.5" grinder.. vice gripped one at a time on and buzzed it in place with 6011/6013 root pass /top pass then hit it with matching paint.
soundguy
   / Where to buy tabs #10
i guess I've been lucky. I've picked up rebar scrap for years and never had a single issue welding with it...ever..?? and I'm certaintly no pro welder.. nor is my ac buzzbox anything special.. :)
soundguy
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
PHENIX TECH HI POT MACHINE (A50854)
PHENIX TECH HI POT...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
2016 FREIGHTLINER M2 DAY CAB (A51222)
2016 FREIGHTLINER...
Nissan 5k Forklift (A51039)
Nissan 5k Forklift...
2011 MAMMOTH UTILITY (A50854)
2011 MAMMOTH...
