Where to buy quick connects
/ Where to buy quick connects #1
rickmacheske
Catharpin, VA
Kubota L3400 HST
I need to get some quick connects for my L3400 rear hydraulics. I installed two stackable valves. The problem that I'm having is that using the standard Pioneer quick connects doesn't work. The ports are too close together so I can't have both valves connected at the same time. My local dealers only seem to carry the standard quick connects. Any ideas? Do you know a place on the web where I can purchase them? They are 3/8".
Thanks,
Rick
/ Where to buy quick connects #3
Have you though about screwing in a short pipe nipple in the valve to put the QDs on. Then you could bend the nipple at a 45* angle or what ever for clearance. I think you will find that there isn't much difference in difference brands. You can get them at your dealer or at a Parker Hydraulic store.
/ Where to buy quick connects #4
A picture would be worth a thousand words here, but I think you will have the same problem with any QD's, the Pioneer one's aren't bigger that anybody else's...
Jerry's suggestion of the nipple's to stagger the coupler's, or 45* fittings to space them out will probably be the best solution.
/ Where to buy quick connects #5
Thanks,
Rick
Are you plumbing the QC's right into the valve then? Anything rigid into the valve itself will need to be staggered and a 45 or 90 to get the QC's away from each other.
Why not run hoses from the valves to a bulk head, which is spaced properly to accept QC's?
Right now the valves are mounted on the rear fender. When I got the stackable valves the dealer said that I could just hook up the attachments directly. He sold me some male end quick connects that looked like they would be placed well enough apart so that I could hook up on each valve. I still have the male ends but couldn't find the female ends. Unfortunately he is no longer in business and I can't find the female ends for the attachments. I had to replace them with Pioneer fittings which are larger. I'm going to take the male ends to another Kubota dealer to see if he has any since the original dealer was Kubota. I did notice that TSC had one "compact" quick connect for 1/2" connections. I was hoping that there was a source with more choice than TSC. A 3/8" compact quick connect looks like it would work just fine.
