Where is the PCV
   / Where is the PCV #11
   / Where is the PCV
From what I can tell, the TC30 had two different designed valve covers and the change point is SN 30000. The early ones had the tall breather on the cover with a hose going down from it. I'm just going from the parts diagram on the Messicks site. Hopefully someone else can chime in with more info.....
Thank you. Im trying to stop[ the blue smoke.
   / Where is the PCV
If it was me, I think I'd plug the fitting going into the intake manifold and route the hose from the breather assembly on the valve cover and down the side of the engine to terminate next to the oil pan, which is exactly how my Kubota's are.
If you are getting excessive blowby (oil vapors) that is indicative of an internal engine issue.
No blowby
   / Where is the PCV #14
I would not get concerned with a gummed up PCV valve then but like I said, I believe I'd plug the fitting and direct the breather hose to atmosphere.
My Kubota's have a sort of valve on the top of the valve cover. It's just a baffle to keep the engine oil from going down the tube and I have almost no blowby either. Little bit but then both units have serious hours on them anyway. 6000 on one and 5500 on the other. My 3406 Cat on the other hand will drip a bit of oil out the road draft tube when it's hot. Keeps the dust down in the gravel driveway,
   / Where is the PCV #15
Blowby is a factor of 2 different things, first is the passage of the compressed fuel-air mixture past worn rings and the second it the physical design of the internal rotating parts of an engine as it relates to pressure changes internally.
All engines will have some blowby. Worn engines will have more.
   / Where is the PCV
I'm going to try this first, hopefully it will work.
Bar's Leaks Oil Seal Engine Oil Burning & Leak Repair Additive, 16.9 oz​
   / Where is the PCV
I can kill the engine and immediately start it again and there is a puff of black smoke, I know this is fuel but why??
   / Where is the PCV #19
Seeing as how there was a change in the crankcase venting after serial number 3000, it would help to know what side of that your tractor is on. As mentioned before, pre-s/n3000 just has a vent tube from the valve cover down the side of the engine towards the ground, essentially a road draft tube from pre pvc days. There is no pvc valve. On the post s/n 3000 models, there will not be that tube going down towards the ground. Apparently there is a vent back into the intake manifold, I do not know that there is a pvc here either, I suspect just some kind of baffling.
If you are getting a puff of black smoke at startup only, I am not so sure that is a blowby issue. Blowby is more consistent and and would occur whenever the engine is running, not just at startup. I would suspect a fuel issue, probably with an injector(s)
Also, note that the service bulletin concern about hydrolock only applies to the after s/n 3000 models that have the crankcase vent to the intake and the oil fill is through the valve cover. The earler models with the vent tube from the valve cover down towards the ground will not hydrolock. If you fill one of these too fast, the oil will simply overflow through the vent tube and end up on the ground, or garage floor.
   / Where is the PCV
There is no blowby. Black smoke at startup.
2023 Ford F-150 4x4 Ext. Cab Pickup Truck (A55852)
2023 Ford F-150...
1987 Ford F800 E-One Pumper Fire Truck (A55852)
1987 Ford F800...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
UNUSED 1RANCH 1RET13 HIGH END ELECTRIC TRICYCLE (A57192)
UNUSED 1RANCH...
2023 Kubota M4-061 Deluxe MFWD Utility Tractor with LA1154 Front Loader (A55315)
2023 Kubota M4-061...
15 TON GRAIN BIN (A57192)
15 TON GRAIN BIN...
