Where is the PCV
   / Where is the PCV #1
macdoesit
Mitsubishi MT 2801fd Loader
Is there a PCV on a 2004 New Holland TC30 Tractor???
Thank you
   / Where is the PCV #2
   / Where is the PCV
PCV valve is normally up under the valve cover. It is used to separate oil from the crankcase vapors and to vent those vapors into the intake manifold. Caution must be used when filling the engine with oil. Too fast and you can fill a cylinder with oil and cause hydrolock. See service bulletin:
file:///C:/Users/Owner/Downloads/Ref%2002%20TC40DA%20Service%20Bulletin.pdf
Do I have to take the valve cover off to change it ?
At startup I'm getting a puff of blue smoke , which is oil, so I think hopefully it is the PCV. Nothing comes up on the link you listed.
   / Where is the PCV
It worked, Thank you. Do I have to take the valve cover off to check the PCV ??
   / Where is the PCV
This is a link for a concoction to stop startup blue smoke. Don't think I would trust it, especially putting planters cashews in the engine. LOL
   / Where is the PCV #7
Reminds me of putting banana peels (blended in a blender) to cure a poor shifting auto trans...
However, an egg white in a radiator will stop a small coolant leak.
   / Where is the PCV #8
Never knew tractors had PCV valves. Neither of mine have them. Both have road draft tubes.
In reality, a PCV Valve should last the life of an engine so long as you change the oil in a timely manner. That applies to a gas engine, not a diesel engine.
   / Where is the PCV #9
From what I can tell, the TC30 had two different designed valve covers and the change point is SN 30000. The early ones had the tall breather on the cover with a hose going down from it. I'm just going from the parts diagram on the Messicks site. Hopefully someone else can chime in with more info.....
   / Where is the PCV #10
If it was me, I think I'd plug the fitting going into the intake manifold and route the hose from the breather assembly on the valve cover and down the side of the engine to terminate next to the oil pan, which is exactly how my Kubota's are.
If you are getting excessive blowby (oil vapors) that is indicative of an internal engine issue.
2022 Polaris Ranger 4x4 Utility Cart (A55851)
2022 Polaris...
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
2012 RAM 5500 Bucket Truck - Cummins Diesel - Automatic - 4X4 - Versalift SST40 Boom (A55302)
2012 RAM 5500...
2025 Future 72in Log Grapple Skid Steer Attachment (A53421)
2025 Future 72in...
2017 Ford F-650 14FT Stakebody Flatbed Truck (A55788)
2017 Ford F-650...
Flatbed Trailer (A51694)
Flatbed Trailer...
