Where is the PCV
   / Where is the PCV #1
macdoesit
Mitsubishi MT 2801fd Loader
Is there a PCV on a 2004 New Holland TC30 Tractor???
Thank you
   / Where is the PCV #2
   / Where is the PCV
PCV valve is normally up under the valve cover. It is used to separate oil from the crankcase vapors and to vent those vapors into the intake manifold. Caution must be used when filling the engine with oil. Too fast and you can fill a cylinder with oil and cause hydrolock. See service bulletin:
file:///C:/Users/Owner/Downloads/Ref%2002%20TC40DA%20Service%20Bulletin.pdf
Do I have to take the valve cover off to change it ?
At startup I'm getting a puff of blue smoke , which is oil, so I think hopefully it is the PCV. Nothing comes up on the link you listed.
   / Where is the PCV
It worked, Thank you. Do I have to take the valve cover off to check the PCV ??
   / Where is the PCV
This is a link for a concoction to stop startup blue smoke. Don't think I would trust it, especially putting planters cashews in the engine. LOL
   / Where is the PCV #7
Reminds me of putting banana peels (blended in a blender) to cure a poor shifting auto trans...
However, an egg white in a radiator will stop a small coolant leak.
   / Where is the PCV #8
Never knew tractors had PCV valves. Neither of mine have them. Both have road draft tubes.
In reality, a PCV Valve should last the life of an engine so long as you change the oil in a timely manner. That applies to a gas engine, not a diesel engine.
   / Where is the PCV #9
From what I can tell, the TC30 had two different designed valve covers and the change point is SN 30000. The early ones had the tall breather on the cover with a hose going down from it. I'm just going from the parts diagram on the Messicks site. Hopefully someone else can chime in with more info.....
   / Where is the PCV #10
If it was me, I think I'd plug the fitting going into the intake manifold and route the hose from the breather assembly on the valve cover and down the side of the engine to terminate next to the oil pan, which is exactly how my Kubota's are.
If you are getting excessive blowby (oil vapors) that is indicative of an internal engine issue.
2015 Chevrolet Express 4500 Shuttle Bus (A53422)
2015 Chevrolet...
2013 FORD F-450XL SUPER DUTY BUCKET TRUCK (A51406)
2013 FORD F-450XL...
2009 Ford F750 Reel Loader Truck (A52377)
2009 Ford F750...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
Pair 2 - ST225/75R15 radial trailer (A53421)
Pair 2 -...
John Deere 6105E Tractor, 105HP, 4WD, Suspension Seat, A/C, 3 Rear Remotes (A55302)
John Deere 6105E...
