Where do you buy tires? What brands to avoid.
   / Where do you buy tires? What brands to avoid. #111
Not crazy about my last carlisle purchase. They changed their tires but call them the same thing. And many sellers are using the old product image so you don't get what you see. Here are my old vs new tires.
Both Carlisle farm specialist r1s. Both 8-16s. Both fully inflated. What gives?
I don't know how they can get away with that, there is no way the section width or the tread width are the same between those two tires.
Section width is obviously way different between the two.
Also the aspect ratio cannot be the same either looking at the pic, (dividing a tire's height off of the rim by its width) Certainly looks like the new R1 has a much higher ratio and they likely did it by shorting on the section width of the carcass, or the section width of the old tire is more eight inches?
Measure section width on both tires 'bulge to bulge' of the side wall is either one 8 inches?
I need to replace both front R1's on my tractor soon and hoping they are not narrowed down either.
Already wish they were a bit wider than what was supplied new. Sure seems like these companies are fudging the numbers today, of course only in their favor as far as material costs.
   / Where do you buy tires? What brands to avoid. #112
Are they both mounted on the same size rim?
   / Where do you buy tires? What brands to avoid. #113
If replacing a single rear Lug tire, Count the Lugs. I wasn't aware that cheaper could mean fewer Lugs and I ended up with Road noise with 4 fewer lugs on a large 4.75 New Holland Tractor rear.
   / Where do you buy tires? What brands to avoid. #114
This is an interesting thread, some of the posts are actually hilarious. That said I spent several hours looking and researching tires this past week.
The Titan Hi-Traction lug R1 tires in 11.2-24 on my Branson 8050 have had some bad looking sidewalls for a few years, the tread is only about half wore down but one of then has developed a split in the center of the tire. I'm going to replace them now rather then in a snowstorm in January after they wad the tire chains up. Titan has 3 tires with the same name and size but different load ratings, all three of them have different loaded rolling circumferences. Because this tractor's main use is snow and driveway maintenance with just a bit of hay ground and planting on occasion I decided not to go back with R1's.
After much research and calculating I'm going with a BKT Ridemax IT 696 it is a traction radial with a much higher load rating then then the Titan 11.2-24 with 8 ply had of 2540 pounds, these new BKT's have a load rating over 4700 pounds. The 300/80R24 spec'ed a bit smaller then my Titans which even at half worn had enough lead to feel when disengaging the 4wd, when I measured the actual loaded rolling circumference which per the spec's was 134", I had about 126" and if I lowered the air pressure I could get down to 123" which no no lead. These tires spec'ed at 129.8".
After much research the best online price was $494 each, one of my local tractor dealers ( a CIH) came in at $505, they should be in this week. I have got to call around for a good mounting price or I may do it my self. At 100+ pounds per tire they will not be too bad.
   / Where do you buy tires? What brands to avoid. #115
I have CEAT’s on the front on my small Challenger. Love the tires, but they are wearing down too fast.
The Cultors on the back wear like iron.
Both made in USA
   / Where do you buy tires? What brands to avoid. #116
I'm afraid to even ask the size. :ROFLMAO:
You oughta see the size & price of these puppies…..
The one rear tire was $4,000.
The fronts were $2,000 each
   / Where do you buy tires? What brands to avoid. #117
I still have the Firestone - 16.9x28 on the rear of the Kubota. I would never consider changing tires myself. I don't have the equipment. Each rear tire is loaded with 775 pounds of RimGuard. Tire, rim and RimGuard > 1000 pounds. One slight slip and "squashed like a bug" comes to mind.
   / Where do you buy tires? What brands to avoid. #118
It isn't as bad as you might think, it takes a bit of time but once the fluid fill is "pumped" or pushed out using air, if you have liquid fill I have bolt on iron. Then the bead is broken with the tires still mounted to the tractor. We don't remove the rim from the tractor during the process. So lifting or moving a heavy tire and rim just the tire which can be a handfull in it's self, my small fronts at 11.2-24 or 300/80-24 are a bit over a 100 pounds each.
2014 Chevy 2500HD Service Truck (A47477)
2014 Chevy 2500HD...
Hydraulic Dingo Attachments (A47477)
Hydraulic Dingo...
2023 54ft Hooklift Dumpster 15 Cubic Yard (A55788)
2023 54ft Hooklift...
New/Unused Quick Attach Pallet Forks (A54865)
New/Unused Quick...
2018 Bobcat T190 Compact Track Loader (A55302)
2018 Bobcat T190...
