Where can I get non-galvanized wire mesh fencing?
   / Where can I get non-galvanized wire mesh fencing? #1
gregfender
Marion, NC
Kubota L2501 HST
Need to build a new pig cooker and the only mesh I can find is galvanized. Does anyone know a supplier that sells this?
   / Where can I get non-galvanized wire mesh fencing? #2
How small of a mesh do you need? 4x4 and up mesh is common for concrete reinforcement.
Could also look at expanded metal, that can be had in non-galvanized versions.
Aaron Z
   / Where can I get non-galvanized wire mesh fencing? #4
If you are looking for something to use as the cooking surface, then expanded metal works very well. I have built several pig cookers, and that is what I always use. Be sure to get the "flattened" configuration for a cooking surface, so that you don't have a problem with sticking.
   / Where can I get non-galvanized wire mesh fencing? #6
expanded metal is at Tractor Supply on the aisle end cap over by the welding and hand tools. Or Lowe's around the hardware department. Mesh for concrete is going to be 6" x 6" so that may be too big for what you're using it for. If you cant find it, look on ebay or metalsdepot.com
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
WERK-BRAY 23" PIN ON BUCKET (A52706)
WERK-BRAY 23" PIN...
207277 (A52708)
207277 (A52708)
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
2023 MADJAX GENESIS 300 ELECTRIC CART (A57192)
2023 MADJAX...
2015 JOHN DEERE 35G EXCAVATOR (A52707)
2015 JOHN DEERE...
