Where can i buy rim guard/beat juice in bulk?
   / Where can i buy rim guard/beat juice in bulk? #11
The alcohol they put in windshield washer fluid to lower its freezing point can destroy rubber tires. Whether it's methanol or ethanol. It causes the rubber to soften, swell and then become brittle.
Good point. One of the things the Bio-ballast literature says is that it conditions the rubber, not degrades it.
   / Where can i buy rim guard/beat juice in bulk? #12
My dealer though it was made from corn so you guess is probably pretty close.
My conclusion, based upon reviewing Bio-Ballast SDS, is based on the freeze point depression due to dissolved solids is likely sugar since undissolved solids have very little effect on freeze point depression and the flash point is very similar in both SDSs. Corn waste makes sense since its cheap and plentiful and quite possibly a residual of ethanol or something ADM is processing since they are consumer of huge corn quantities.
   / Where can i buy rim guard/beat juice in bulk? #13
Alcohol, in sufficient concentration, is also corrosive to brass. Don't know its effect on valve stems as I've never run it in tires.
   / Where can i buy rim guard/beat juice in bulk? #14
My last tractor that I sold in 2021 had a mixture of methanol and water for about ten years. I never noticed any corrosion on valve stems or effects on tires, but maybe give it a few more years?
   / Where can i buy rim guard/beat juice in bulk? #15
My current tractor has this mixture also. Purchased in 2007 with tires loaded. Metal valve stems still like new, not sure about inside of tires and rims but nothing visually concerning
   / Where can i buy rim guard/beat juice in bulk? #16
Title pretty much says it all. I want to put ballast in my tires and they hold 70 gal each. I'm thinking 55gal drums would be ideal. 2 barrels would give me 1200 lb of Ballesteros which should be plenty.
Although heavily advertised in farm pubs, Rim Guard isn't always available locally. Shipping might be somewhat pricey from a stocking dealer.
What I did was simply use a couple of clean 55 gal drums (with intact bung plugs) and drive an hour to a farm implement dealer who had it in bulk storage. They just pumped it into my drums and I had my tire guy pump from the drums into the tractor tires back at the farm.
I've forgotten the price now, but it seemed reasonable...for root juice.
Best of Luck.
   / Where can i buy rim guard/beat juice in bulk? #17
Just repeating what science says. Did you check the inside of the tires? You could have been running on tires no more than 1/8" thick.
   / Where can i buy rim guard/beat juice in bulk? #18
And you could be right. Probably good that I sold that tractor 3 years ago.
   / Where can i buy rim guard/beat juice in bulk? #19
   / Where can i buy rim guard/beat juice in bulk? #20
I use molasses get it in 275 gallon drums or 55 gal barrels from the feed warehouse. Molasses I think is denser than the beet juice. Needs to be warm otherwise it’s slow. I used air to push it in because the pump burned out. Plumbed the 55 gal barrel to take air chuck and only used about 20 psi and it went in really fast. Much faster than pumping it in. Used a air water separator connector to pause and release air a few times per tire.
2008 KENWORTH T300 FLATBED FUEL TRANSPORT TRUCK (A58214)
2008 KENWORTH T300...
500 BBL FRAC TANK (A58216)
500 BBL FRAC TANK...
NEW PIG DRM654 HYD WASTE COMPACTOR (A58376)
NEW PIG DRM654 HYD...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2019 Ford F-150...
Set of 4 12-16.5 Bobcat Wheels and Tires (A56857)
Set of 4 12-16.5...
John Deere Tractor Weights (A57149)
John Deere Tractor...
