Where are the drain plugs on my komatsu d37p
   / Where are the drain plugs on my komatsu d37p #1
Cplum98
Komatsu d37p
I need to drain the oil from the dozer from the drives. Is there an access point underneath?
   / Where are the drain plugs on my komatsu d37p #2
Welcome to TBN. :)
   / Where are the drain plugs on my komatsu d37p #3
WELCOME to TBN :)
I moved your thread to the Construction Equipment Forum.
Thank you, there are three dipsticks under seat, I assume these are the drive reservoirs. Sae 30 oil goes in it. So the drain for these is underneath? Thanks
   / Where are the drain plugs on my komatsu d37p #7
Don't know if I'd want to use SAE 30 in the final drives. Are you sure those dipsticks aren't for the steering clutches and differential?
What does your manual call for?
I don't have a manual. Hence the message post. It may be the steering clutches. The middle one has some water in it though and I need to drain it. Any advice?
   / Where are the drain plugs on my komatsu d37p #9
Get a manual - really. I am not trying to be wise.
   / Where are the drain plugs on my komatsu d37p #10
The middle one is not the final drive. The final drives are outboard of the steering clutches.
2020 CHEVROLET 2500HD CREW CAB TRUCK (A51406)
2020 CHEVROLET...
JOHN DEERE 6615 TRACTOR (A51406)
JOHN DEERE 6615...
2014 Nissan Pathfinder SUV (A51694)
2014 Nissan...
2011 Ford F-350 Knapheide Service Truck (A54814)
2011 Ford F-350...
2007 Ford F-150 Crew Cab Pickup Truck (A53422)
2007 Ford F-150...
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A52705)
2019 CATERPILLAR...
